1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22257 09/09/2004 11:53 PM | Joined: Sep 2004 Posts: 7 Junior Member | | Junior Member Joined: Sep 2004 Posts: 7 | My 58' 235 locked up on me. Unsure of the engine history. Should I look for a new engine or should I have it rebuilt? I'm probably going to switch out the rear end so its not so low geared. Any recommedations? | | |
#22258 09/10/2004 12:49 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | How about you rebuild it? A few books and some time and you can probably do it. Have someone else do the head work. What have you got to lose?
As far as the rear? I keep hearing GM 10 bolt out of a 2nd gen F-body...like Camaro or Firebird.
Not sure for your 58 tho. | | |
#22259 09/10/2004 1:49 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | GV: I am running a complete 1969 Grand Prix axles and rearend. 3.55 gears matches up perfect.
popcorn The Truth is Out There (Get your tape and measure twice) | | |
#22260 09/10/2004 7:45 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You won't find a "new" engine that will drop into your truck without some modification. Usually you can rebuild the 235 block.
Did your engine lock up from setting, or while driving. If it's from rust and setting, there is a good chance of freeing her up.
Fred 52 3600 69 C-10
#22261 09/10/2004 10:26 PM | Joined: Sep 2004 Posts: 7 Junior Member | | Junior Member Joined: Sep 2004 Posts: 7 | It locked up while driving. I wasn't sure what was wrong so I tried to turn it over, but it sounded like it had taken my exhaust manifold off. | | |
