1 members (Russ_B_10), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
#222234 12/19/2006 2:15 PM
Just finished my truck yesterday. Took it for a test drive and everything worked. Only one problem. At a speed of between 30 or 50, when hitting the brakes, the truck wants to steer off to the left. I put new brakes on the rear so thought maybe they just need to be seated in. Also, checked the tire air pressure. Any thoughts on how to adjust. Thanks. :confused:
#222235 12/19/2006 11:02 PM
Riding in the Passing Lane
It could be that the rear brakes aren,t seated but more likely the fronts have a problem. It could be fluid or grease leaking on the linings, stuck wheel cylinders, bad brake hoses, or loose wheel brgs.
1972 Chevy c10 Cheyenne Super
#222236 12/20/2006 2:11 AM
ODSS Lawman
ODSS Lawman
Did you adjust your brakes properly? If the right side is not adjusted per the shop manual instructins, the truck would steer left.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
#222237 12/20/2006 3:07 AM
i would agree with 51. if the shoes are set unevenly, the truck will pull to the "tighter" side.
back the shoes off on the side that it pulls towards or tighten the shoes up on the non-pull side and take another test drive. if the condition persists then investigate wrenchbender's theory.
#222238 12/20/2006 4:17 AM
Thanks everyone, I will give those thoughts a try later this week.
#222239 12/20/2006 6:08 AM
Quote
this same thing occured not 6 months ago and I found out that the front LT brake cyl. was NO GOOD so I changed both RT and LT brake Cyl. and the linings.
And now she brakes just great, and NO PULL TO THE LEFT. smile
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#222240 12/20/2006 11:12 PM
Wrenchbender Ret, I tried some of your advise and found that the left front wheel bearing nut needed to be tightened. Apparently after driving the test drive, it loosened up a bit. Turned the nut about 1/2 turn to tighten and now it does not have any wobble. Think this could be the problem of pulling to the left when braking. Haven't had a chance to drive since I did the above due to weather so don't know if the brakes are adjusted just right or not.
#222241 12/22/2006 10:11 PM
I may have found part of my problem on the brake sway. After examining the bearings and hub, I found out that the inner bearing is cracked and one ball bearing will fall out of it. I will replace that. Also, the inner bearing will not stay in the hub because there is not any felt lining to hold it in. This may be a loose bearing affecting the brakes. :mad: Do any of you know of a replacement felt or a way to hold the bearing in place so it will not drop out? Normally they just tap out. I have a new bearing to replace the old one but no felt. Any thoughts. :confused:
#222242 12/22/2006 11:29 PM
The felt is part of the front wheel grease seal. Buy one from any parts place.
