| | | Forums66 Topics128,050 Posts1,055,753 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Just finished my truck yesterday. Took it for a test drive and everything worked. Only one problem. At a speed of between 30 or 50, when hitting the brakes, the truck wants to steer off to the left. I put new brakes on the rear so thought maybe they just need to be seated in. Also, checked the tire air pressure. Any thoughts on how to adjust. Thanks. :confused: | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It could be that the rear brakes aren,t seated but more likely the fronts have a problem. It could be fluid or grease leaking on the linings, stuck wheel cylinders, bad brake hoses, or loose wheel brgs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Did you adjust your brakes properly? If the right side is not adjusted per the shop manual instructins, the truck would steer left.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | i would agree with 51. if the shoes are set unevenly, the truck will pull to the "tighter" side.
back the shoes off on the side that it pulls towards or tighten the shoes up on the non-pull side and take another test drive. if the condition persists then investigate wrenchbender's theory. | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Thanks everyone, I will give those thoughts a try later this week. | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Originally posted by Wrenchbender Ret.: It could be that the rear brakes aren,t seated but more likely the fronts have a problem. It could be fluid or grease leaking on the linings, this same thing occured not 6 months ago and I found out that the front LT brake cyl. was NO GOOD so I changed both RT and LT brake Cyl. and the linings. And now she brakes just great, and NO PULL TO THE LEFT. Cliff59 | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | Wrenchbender Ret, I tried some of your advise and found that the left front wheel bearing nut needed to be tightened. Apparently after driving the test drive, it loosened up a bit. Turned the nut about 1/2 turn to tighten and now it does not have any wobble. Think this could be the problem of pulling to the left when braking. Haven't had a chance to drive since I did the above due to weather so don't know if the brakes are adjusted just right or not. | | | | | Joined: Jul 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 163 | I may have found part of my problem on the brake sway. After examining the bearings and hub, I found out that the inner bearing is cracked and one ball bearing will fall out of it. I will replace that. Also, the inner bearing will not stay in the hub because there is not any felt lining to hold it in. This may be a loose bearing affecting the brakes. :mad: Do any of you know of a replacement felt or a way to hold the bearing in place so it will not drop out? Normally they just tap out. I have a new bearing to replace the old one but no felt. Any thoughts. :confused: | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The felt is part of the front wheel grease seal. Buy one from any parts place. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
