| | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | :mad: 52 days. I've been arguing with my dear truck for 52 days about this project that was called a disc conversion for the front brakes. I've gone through ball joints, tie rods, and just about everything else that is involved with these particular areas. I ordered brand new lines and conversion kits from LMC. And today, my 53rd day, I'm finally putting the wheels back on to get her on the road. :mad: Yea, right? NOT!!! :mad: This kit is supposed to be able to convert a completely stock truck to disc. :mad: If this is the case, then why, Why, WHY does the flippin' brake caliper mash against the flippin' wheel rim when I bolt them on??????????? :mad: :mad: :mad: For the love of God and everything that is holy, please, someone out there tell me that I just did a bonehead thing and then tell me the fix!!! :confused: I called LMC prepared to completely and totally devour someone, and their flippin' tech service is only available on weekdays.....
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might check cletis site and see if it helps look here Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | vader, sorry, dont know if that will help,,
you have a 65 chevy, dont you? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Yeah man. I was looking on that site and the only thing that I saw that might help was the metal removal around the riveted areas on the rims. Something about that seems a bit scary to me though, you know?
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | If you're running disc brakes, you have to have the newer style steel wheels. They will clear the calipers. Old original style won't.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Are you serious?? I can't believe that this stupid catalog told me everything else that I needed to upgrade the brakes, but neglected to mention that I needed different rims. Wow. That is very frustrating...
| | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Relax, make a trip to the local wrecking yard and pick up a set...
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Some wheels will clear, some won't. The wheels on my buddy's 69 wouldn't fit, but the ones from my 64 would clear(barely). Both sets of wheels looked the same, same sze & width, until you turned them around & they had a slight difference in the riveted area. So, if you want to keep stock wheels look around the boneyard like RR said. Also 4x4 C10 wheels up to 87 fit & give you more width. Brian | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | My disc brake conversion on my 65 was courtesy of OEM parts. I swapped in spindles from an 84 C10. Converted the truck to 5 hole wheels. A true bolt in project. I had to change the ball joints, brake hoses and tie rod ends. All OE parts. Sorry yours was not as easy.
Measure your spacing: both back space and distance from hub center to outside of caliper. Take that measurement with you to the junkyard and find a set of rims that work. The problem may lie with the shape of the inner part of the rim and the way it comes down from the bead. Other rims of this vintage may not have as deep of a droop. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I'm sure I saw it mentioned on one of the conversion ads that depending on which wheels you have,you might need to use 1/8 inch spacers,which they offered for sale. Would that help you? Speed | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Dearth, Too bad you don't live closer. I've got a set of regular steel wheels that worked perfect on my Mustang II front end that I'd give you.
| | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Dearth, My 83 has the wheels that you need. George
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
| | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Well fellas, I think that it just has to do with the kit that I got. I went to a few different junk yards, picked up 5 different rims that I suspected might fit, and ALL of them rub. Long story short, I've been in touch with LMC for a caliper exchange -- apparently they have a thinner set of calipers that can work with that kit... Thanks a lot for the other helps! On the flip side, there may be something good coming out of this -- I started looking for new rims that might work and I found some that would look GREAT with the whole theme that I have planned...
