4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
#221886 12/16/2006 3:07 AM
Apprentice
Apprentice
I have a 57 chevy 3100 stepside and would like to locate the battery under the passengers side of the cab with some remote battery posts mounted inside the cab. Has anyone done this before? Any recommendations on kits, or what you did? Thanks,, Dave
you may want to add a drop down battery box, available from most street rod catalogs. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
what are you going to do with the "remote" battery posts?
Another quality post.
Real Trucks Rattle
Socket Breaker
Socket Breaker
Just run longer cables to the battery... using the drop down box like "we b old" mentioned.
-W
You could also adapt a battery access door from an AD truck for access to the battery, they're available from the parts suppliers on the Links page.
Bill Burmeister
Apprentice
Apprentice
The remote battery posts are to jump the battery if needed, without having to crawl under the truck or drop the battery to do it.
Locate the battery where your passenger's feet go, and put in a removable plate. Voila! Problem solved. (That's where the battery is in an AD truck)
If you just need it to jump the battery use jumper cables that have a connector where you can plug in your cables and hide the connector under the running board or inside the front fender. Check this link for a picture.
http://www.projectresponder.com/jumper-cables~5~110.htm
Former Workshop Owner
Very interesting, I have never heard of jumper cables with this feature. I may consider trying them on one of my trucks.
Thanks for the tip.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
you just need one hot post just use a big nut and bolt with insolating washers mount it wear ever you need it the other jumper just ground on the frame
I like that cable set up also. Thanks for posting the link. Reminds me of the old aircraft to power cart hook up.
1937 Chevy 1/2-Ton
I have seen them used alot on emergency vehicles for quick access, but I think they would be real handy on any vehicle.
