3 members (Maybellene, LAJones48, Gazz), 129 guests, and 4 robots.
Topics128,096
Posts1,056,482
Members48,444
I've looked through several search results and can't find an answer to my question... can I put a '67-'72 automatic steering column in my '65 C-10 without too much trouble?
Thanks.
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
It is a pretty easy swap. Toughest part is re-wiring the signals, but color for color usually works. Most have hazard lights, this wire needs 12v thru a separate flasher in order for the hazards to work(brown wire IIRC). Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I have done this swap on my 64. I put a 71 column in it. The wiring was not color for color. I made a strap to fasten it under the dash, (easy). Drill out the plastic pins that hold the 2 peices of the column together, the part that allows the column to colapse in a collision. You may have to change the end where the rag joint fits. You will probably have to fashion shift linkage. I used the rod from a 70s el camino jack. It is pretty srraight foward,just take your time and do a little shade tree engineering. But remember, that is your only contact with the road!
Socket Breaker
Socket Breaker
I don't know how to do it, but this is what it looks like:
http://matraca.home.mindspring.com/img03112006/12.html
I've been told by '67-'72 chevy truck guys that the column there is a '71... and '71 parts fit it, so I guess it is.
There are other pictures on my site of the interior if you want more shots.
-W
Woogeroo:
The steering column looks great. Those are some high tech underdash speaker mounts.
Tony
Socket Breaker
Socket Breaker
Quote
Originally posted by 4-5-6 Chevy Trucks:
Woogeroo:
Tony
I had to pay extra for those custom speaker mounts.
When I bought the truck, the speakers were just stuck under the dash with the speaker magnets holding them to the metal body. I found this out one day rolling over a rail road track.
'aaaah, what's on my foot!?'
grin
'what in the... ?'
-W
