| | | Forums66 Topics128,035 Posts1,055,570 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | I have an old flathead Dodge 6 that I found in a barn. I got the motor freed up but it smokes like crazy. I'm sure that the rings are stuck. Is there any "solution" that will unstick the rings? I know that this is the Stovebolt forum, but I couldn't turn the deal on the old Dodge. Thanks. | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Well when we fired up my 1935 Dodge sedan after sitting in a garage for about 15 years we had similar issues and were able to use liberal amounts of Marvel Mystery Oil soakings and some persuasion to get a stuck valve freed up. It has done well for the past 5 years.
Good luck!!!
1946 Chevy Pickip
| | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Believe it or not it will probably improve to some degree just by driving it. The old standard method of breaking in a new or rebuilt motor by accelerating and decelerating to "load" up the rings and help them seat will work. It did with my 50 Chevy 216. Or is it just a motor without a car? Now would be the best time to overhaul it without any sheet metal in the way.
Professional Novice
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have replaced two quarts of engine oil for two quarts of ATF oil. Let it run and drive it (slow) with out beating on it for 45 minutes or so. | | |
