1 members (Hotrod Lincoln), 75 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#220386 11/25/2006 10:33 AM
Hi guys,
My 41 gets hot sitting in traffic on 80 plus degree days. I've cleaned the block, checked the thermostat ( 160 ), drilled a 1/8 hole in the stat collar,had the radiator cleaned and rodded out,new fan belt, upped the idle speed a wee bit, timing and valve clearances, fuel mix ok, hasnt made any difference. Just wondering if a larger pulley would help. The one on the pump at the moment is about 4 inches. Also thinking about a electric pusher fan. I'd be grateful for any comments.
Cheers guys
Bob
Maybe try a fan with more pitch that will pull more air and see if that helps. If the truck runs hot at idle, and then cools down right away when you get moving, I'll bet more pitch helps. If you have room, you could try an aftermarket aluminum flex fan or something similar temporarily to test this theory out.
To be long remembered as he's cruising in
The Passing Lane
A larger pulley will make it turn slower. I agree with Barry, more pitch on the fan might do it.
Good luck with it.
Thanks Barry and Rob. There isn't a lot of room between the fan and the radiator but I'll have a look around and try another blade. It takes a mile or two to drop back to normal once it gerts moving.
All the best
Bob
Any idea how to repitch a blade? I have the same problem with mine here in North Centeral Texas.I must point out that I have an AC on my truck and I know the additional blockage with the condencer doesn't help also. "Tie me kangeroo down sport".Nice to here from down under.
mozzie,
It sounds like the combination of engine age/wear/friction/heat combined with a old cooling system won't get the job done when the ambient temperature climbs and the traffic slows.
Although your radiator has been boiled, I will bet it isn't cooling anywhere near new. Would a re-core be an option...maybe another row of tubes. I'll bet this was solve the 'hot day blues'.
Stuart
Hey Beaver, thanks mate, kangaroos are a bit hard to tie down though (ha ha )
Stuart, radiator was stripped cleaned and rodded through. The rad shop reckons it was in pretty good shape.Its a three row, modern core. Engine has about 20,000 miles since rebuild. I just thought that a bigger pulley might slow the circulation speed down a bit and help with cooling.
As always, thanks guys.
Bob
#220393 11/26/2006 11:29 AM
Hey Bob, I didn't think there was, any traffic in western Australia??
I have been kicking the idea around, about bending up or adapting a shroud, there is a lot of loss at the tips of the blade. I'm assuming your savvy enough to be running modern day glycol antifreeze and not just water or alcohol!
Denny Graham
Western Sandwich, IL, USA
Denny G
Sandwich, IL
#220394 11/26/2006 12:58 PM
If the motor has just been rebuilt is their any chance that you ended up with a later model harmonic balancer. The later 235 balancer is bigger and would turn the water pump faster.
Junior Member
Junior Member
you can get great metal cooling fans, not the aluminum flex fans from vintage air. look for them at vintageair.com. i've used them on my street rods for years. they are a bit noisey.
Thanks again guys,
Denny......there are a few cars out here, does get pretty hot as well this time of year. Yep running ainti freeze and made up a shroud to see if it would help.
ttodd......I'll have to check up on the balancer. What diameter was the original?
lms.....I'll have a look at the vintage air site. Thanks for the info.
Cheers
Bob
#220397 11/27/2006 12:23 AM
i had the same problem on my 47 fleetmaster with a 350. i put a electric fan in front of the radiator in addition to the stock fan i can sit idle on the hotest day in ca and it wont over heat. it sure made me happy cruisin paso when you see a merc built with unlimited funds overheat and you cruise by them.
1949 SUBURBAN
Mozzie:
Late ignition timing will also make it run a little hotter. Also are you sure the thermostat is not in backwards?
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
John...thinking about a fan in front with an on/off switch in the dash so I would only have it on when needed.
Kip...timing is fine mate and I double checked the thermostat in case it flipped when I installed it.
Cheers folks
Mozzie
Yet another idea. What is the altitude where you are. Assuming you may not be running a pressure cap at higher altitudes water boils at lower temperatures. Check here. http://www.biggreenegg.com/boilingPoint.htm
This is also a good chart for pressure systems http://www.engineeringtoolbox.com/boiling-point-water-d_926.html
Of course this all changes with any kind of antifreeze mixture
