2 members (TUTS 59, 1 invisible),
152
Mod | | | Forums66 Topics128,089 Posts1,056,362 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Hi guys,
My 41 gets hot sitting in traffic on 80 plus degree days. I've cleaned the block, checked the thermostat ( 160 ), drilled a 1/8 hole in the stat collar,had the radiator cleaned and rodded out,new fan belt, upped the idle speed a wee bit, timing and valve clearances, fuel mix ok, hasnt made any difference. Just wondering if a larger pulley would help. The one on the pump at the moment is about 4 inches. Also thinking about a electric pusher fan. I'd be grateful for any comments.
Cheers guys
Bob | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Maybe try a fan with more pitch that will pull more air and see if that helps. If the truck runs hot at idle, and then cools down right away when you get moving, I'll bet more pitch helps. If you have room, you could try an aftermarket aluminum flex fan or something similar temporarily to test this theory out. | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | A larger pulley will make it turn slower. I agree with Barry, more pitch on the fan might do it. Good luck with it. | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Thanks Barry and Rob. There isn't a lot of room between the fan and the radiator but I'll have a look around and try another blade. It takes a mile or two to drop back to normal once it gerts moving.
All the best
Bob | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Any idea how to repitch a blade? I have the same problem with mine here in North Centeral Texas.I must point out that I have an AC on my truck and I know the additional blockage with the condencer doesn't help also. "Tie me kangeroo down sport".Nice to here from down under. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mozzie,
It sounds like the combination of engine age/wear/friction/heat combined with a old cooling system won't get the job done when the ambient temperature climbs and the traffic slows.
Although your radiator has been boiled, I will bet it isn't cooling anywhere near new. Would a re-core be an option...maybe another row of tubes. I'll bet this was solve the 'hot day blues'.
Stuart | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Hey Beaver, thanks mate, kangaroos are a bit hard to tie down though (ha ha )
Stuart, radiator was stripped cleaned and rodded through. The rad shop reckons it was in pretty good shape.Its a three row, modern core. Engine has about 20,000 miles since rebuild. I just thought that a bigger pulley might slow the circulation speed down a bit and help with cooling.
As always, thanks guys.
Bob | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hey Bob, I didn't think there was, any traffic in western Australia?? I have been kicking the idea around, about bending up or adapting a shroud, there is a lot of loss at the tips of the blade. I'm assuming your savvy enough to be running modern day glycol antifreeze and not just water or alcohol! Denny Graham Western Sandwich, IL, USA
Denny G Sandwich, IL
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If the motor has just been rebuilt is their any chance that you ended up with a later model harmonic balancer. The later 235 balancer is bigger and would turn the water pump faster. | | | | | Joined: Oct 2006 Posts: 22 Junior Member | | Junior Member Joined: Oct 2006 Posts: 22 | you can get great metal cooling fans, not the aluminum flex fans from vintage air. look for them at vintageair.com. i've used them on my street rods for years. they are a bit noisey. | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Thanks again guys,
Denny......there are a few cars out here, does get pretty hot as well this time of year. Yep running ainti freeze and made up a shroud to see if it would help.
ttodd......I'll have to check up on the balancer. What diameter was the original?
lms.....I'll have a look at the vintage air site. Thanks for the info.
Cheers
Bob | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i had the same problem on my 47 fleetmaster with a 350. i put a electric fan in front of the radiator in addition to the stock fan i can sit idle on the hotest day in ca and it wont over heat. it sure made me happy cruisin paso when you see a merc built with unlimited funds overheat and you cruise by them. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Mozzie:
Late ignition timing will also make it run a little hotter. Also are you sure the thermostat is not in backwards? | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | John...thinking about a fan in front with an on/off switch in the dash so I would only have it on when needed.
Kip...timing is fine mate and I double checked the thermostat in case it flipped when I installed it.
Cheers folks | | |
