0 members (), 88 guests, and 3 robots.
Topics128,143
Posts1,056,494
Members48,442
#220358 11/24/2006 5:28 PM
Apprentice
Apprentice
I just completed sand plasting some steel wheels that I want to put on my 52'chevy. My proplem is this, the steel is still a little pitted. Is there a thick primer that I can spray on these to fill in some of the pits? Or any other ideas?
westerman
52' CHEVY 3100
#220359 11/24/2006 5:30 PM
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#220360 11/25/2006 9:38 AM
Junior Member
Junior Member
use a good 2pack primer filler, either brush on , roller or spray, or fine surface stopper filler,patience at this stage should give perfect results, finish in a good 2k paint, carefull putting tyres back on, steve.
#220361 11/25/2006 4:21 PM
Ex Hall Monitor
Ex Hall Monitor
I left the pits in mine and had them powdercoated. You can't tell the pits are there unless you're on your knees next to the wheel. Also, if the sandblaster wasn't careful the wheels could be warped now. It would be wise to check the run-out before putting any more money or effort into them.
