| | | Forums66 Topics128,130 Posts1,056,370 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 26 Apprentice | | Apprentice Joined: Oct 2006 Posts: 26 | I just completed sand plasting some steel wheels that I want to put on my 52'chevy. My proplem is this, the steel is still a little pitted. Is there a thick primer that I can spray on these to fill in some of the pits? Or any other ideas?
westerman 52' CHEVY 3100
| | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | | | | | | Joined: Sep 2006 Posts: 18 Junior Member | | Junior Member Joined: Sep 2006 Posts: 18 | use a good 2pack primer filler, either brush on , roller or spray, or fine surface stopper filler,patience at this stage should give perfect results, finish in a good 2k paint, carefull putting tyres back on, steve. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I left the pits in mine and had them powdercoated. You can't tell the pits are there unless you're on your knees next to the wheel. Also, if the sandblaster wasn't careful the wheels could be warped now. It would be wise to check the run-out before putting any more money or effort into them.
