3 members (60steve, rfs56trk, TexasA&M48Truck), 79 guests, and 0 robots.
Topics128,212
Posts1,057,463
Members48,471
how's everybody doing, just started using stovebolt,looking for ideas to move my gas tank to my bed of my 1/2 ton pu, any ideas would help thanks in advance
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
Perro - ideas are mostly find a donor tank, mount it between the rear frame rails, figure how to put a filler thru the floor or fender, patch the filler hole in the cab .... which most seem to think is more work than it's worth grin
moving the tank is one of the more common things discussed here - try a forum search
Perro,
I've done it both ways. I have the original behind-the-seat tank re-mounted at the front of the bed. It wasn't all that difficult . . . unless you're somewhat lazy. I sure like the cab room I now have. I have a second 25 gal, fuel tank mounted behind the rear axle with the filler opening at the back of the bed. You may have to use air-lift shocks to keep that fuel tank from dragging when full. They're cheap.
Good luck!
Apace Kid,
When u mounted the tank at the front of the bed,what did you use for the filler, How did you mount it etc.
Perro
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
I moved the tank on my 46 to under the bed, just moved back to original spot. I had rigged the stock filler from side of cab, through floor into new tank inside frame. Had trouble filling the tank this way so be sure to have a filler door somewhere near the tank. Have seen little flip up lids in the wooden floor, etc.
1946 1/2-Ton Chevy
