7 members (HandyAndy, RoadsScholar, Wayne67vert, Peggy M, moparguy, ESum, 1 invisible),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,467 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | how's everybody doing, just started using stovebolt,looking for ideas to move my gas tank to my bed of my 1/2 ton pu, any ideas would help thanks in advance
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Perro - ideas are mostly find a donor tank, mount it between the rear frame rails, figure how to put a filler thru the floor or fender, patch the filler hole in the cab .... which most seem to think is more work than it's worth moving the tank is one of the more common things discussed here - try a forum search Bill | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Perro,
I've done it both ways. I have the original behind-the-seat tank re-mounted at the front of the bed. It wasn't all that difficult . . . unless you're somewhat lazy. I sure like the cab room I now have. I have a second 25 gal, fuel tank mounted behind the rear axle with the filler opening at the back of the bed. You may have to use air-lift shocks to keep that fuel tank from dragging when full. They're cheap. Good luck! | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Apace Kid, When u mounted the tank at the front of the bed,what did you use for the filler, How did you mount it etc. Thanks Perro
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I moved the tank on my 46 to under the bed, just moved back to original spot. I had rigged the stock filler from side of cab, through floor into new tank inside frame. Had trouble filling the tank this way so be sure to have a filler door somewhere near the tank. Have seen little flip up lids in the wooden floor, etc. | | |
