6 members (Gdads51, cmayna, Hambone, dt235sd, papas52, Bruce 1954-4100), 137 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
I figure this vibration has something to do with the carrier bearing, but here's the deal. Going downhill in 4th with clutch engaged...pretty standard stuff. Take it out of gear and coast...jars your teeth. Why does it not do it when the driveline is loaded?
Dash Riprocker
Maybe because it's (whatever "it" is) torqued over and "pinned" into a certain spot and when you let off, it's free to flop around. Just a guess here,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
U joints?
Usually a U joint will vibrate under load. I'm inclined to think it could be the carrier. Checking the joints wouldn't hurt either.
Bill Burmeister
