2 members (Tronman, Gray_Ghost), 85 guests, and 1 robot.
Topics128,142
Posts1,056,476
Members48,441
#218795 11/02/2006 3:24 AM
Fellow bolters need your help. While driving home tonight in my wife's 2000 explorer I ran over an object in the road that put a nice little cut in the lower corner of the fuel tank.I am a welder by profession but looking for an eazy solution to the problem.I was wondering about using J-B Weld, any body have good sucess with this sort of problem?
#218796 11/02/2006 3:31 AM
I patched a hole in my gas take using a 2 part compound. I don't know the name of it but it's like putty that came in a round tube. Cut off how much you need and mixing in your hands and stick it on. I fixed that hole about 7 years ago and it still holds gas.
38 original
48 panel
59 stepside
46 in the back forty
#218797 11/02/2006 3:37 AM
quick steel works well as long as it is dry and jb weld works to if need temp fix use a bar of sope to run tank dry
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#218798 11/02/2006 4:33 AM
They sell a gas tank repair kit that has a wax or something that you work into the hole to temporarily stop the leak. You then apply an epoxy over that for the permanent fix. I would go to a parts house and see what's available,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#218799 11/02/2006 5:11 AM
Several years ago I hit hard on the oilpan in my '68 Corvette when going over a speed bump coming out of a casino in Reno, NV. It was late afternoon on a Sunday and the closest garage that was open used J-B weld to plug the hole (about the size of my little finger). I drove the car 200 miles to home and it never leaked another drop. Of course I had a new pan put on the next day but it proved to me the value of J-B weld. It sure should seal a gas tank leak.
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
#218800 11/02/2006 5:17 AM
I used j-b weld on a sedan delivery gas tank quite a few years back,,,its still holding. good stuff.
#218801 11/02/2006 5:31 AM
Seal-all. Just slather it right on the gas as it leaks out the hole. We use it in the bush all the time. Quick, easy and permanent.
1951 3800
-hotshoe
#218802 11/02/2006 12:26 PM
Thanks guys, knew I could depend on a good help solution. Neal
53 3100
#218803 11/02/2006 12:43 PM
napa has a fiber glass patch made for gas tanks it works good ive used one never had to look at it again didnt have to pull the tank sanded it to clean metal around the area
#218804 11/02/2006 4:06 PM
in an emergency, you can often seal a small hole with a piece of wood jammed into the hole...
Another quality post.
Real Trucks Rattle
#218805 11/03/2006 2:32 AM
Well, hole is sealed, used a stuff that you kneed and put a small portion in to the hole, then used J-B and put 4-5 thin layer over, filled tank and all seems ok so far, THANKS FOR YOUR HELP. "This could never happened to a 53 3100./Tank is in cab". Neal
