3 members (Bill Hanlon, ShopRag, HandyAndy), 73 guests, and 2 robots.
Topics128,049
Posts1,055,676
#218754 11/01/2006 4:18 AM
1 Offline
(1964 C-10 with a 283 and the previous owner put a 3 speed auto in it. I got the truck in the spring.)
I have been trying to put on a starter for some time and finally I got a real mechanic out to look at it and he said that all he could figure out was that the flywheel was on backwards. All of the new starters that we tried didn't engage far enough on to the flywheel. One guy also mentioned the flexplate. I am no mechanic other than simple things so if anybody wants to shed light on this situation feel free to.
#218755 11/01/2006 4:43 AM
I have seen it done before,,things worked but not right & it ate starters. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#218756 11/01/2006 4:58 AM
1Dollar,
There was a similar post in the 'Engine' forum last week. This is my take on the situation.
If the flywheel is on correctly...everything is where it should be. If the flywheel is on backwards, it is too close to the starter snout, and jambs when engaged.
I read it to be 'correct' or 'too close', but not too far away.
If you go to the 'Engine and Driveline' forum, and do a search using 'flywheel on backwards', you will find a post that reads "flywheel position". There is a link to some pictures of a SBC flexplate installed on the engine.
The flexplate has dimples that stick out and are flat mounting pads for the converter to bolt through. Take a look.
Stuart
#218757 11/01/2006 4:59 AM
1 Offline
I think that is what mine has because the old starter had a broken tooth and stopped engaging properly while mahing that terrible grinding noise.
Thanks for the quick reply
#218758 11/02/2006 4:40 AM
For one reason or another, the torque converter may not be completely seated into the end of the crankshaft and may be "pulling" the flex plate away from the engine a bit. Could try loosening the torque converter bolts to see if there's any tension there,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
