| | | Forums66 Topics128,090 Posts1,056,028 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 12 | I am in the process of restoring a 1941 GMC 3/4 steak bed. I am going to move the tank from inside to under the bed..... has anyone done this and what type of tank did you use? I found the demensions of a 54 chevy tank will fit where I want it to go. Just looking for more ideas and input. Also I need the leg room in the cab... I'm 6'6" so I'm redoing the interior. What has anyony used for seats that go all the way back against the back of the cab? Thanks for any input you might have. Dave. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | What is your inseam? I'm a tall guy too. I fit my stock AD seat with it all the way back but when I used to have a '55 CJ-5 I couldn't get my knees under the steering wheel. I got some seats from Steel Horse and made new mounting brackets.
Either offroad or racing seats tend to have thin backs and upright seating positions and should work for you.
Good luck, though, the '41 cab is pretty small.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | No body seems to like the way I did my tank on my 54 G M C but I used a water preasure tank and mounted it on the left side under the flat bed. I used pipe fittings to make a filler tube and steel tubing for a pick up tube. It works for me.
I like old trucks
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Use a beer keg. Put a high polish on it when the fab work is done and you'll have a real show piece, Scott | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | I used a stainless steel LPG tank. Our Laws wont let me use it as a LPG tank. However i can use it for Petrol. Go Figure! Brendon | | |
