3 members (Oswald, Otto Skorzeny, greenie-reddy), 331 guests, and 5 robots.
Topics128,162
Posts1,057,058
Members48,463
What is the best way to clean stuff like the hinges, striker plates, etc, etc... like all of the small stuff that I am going to reuse... Should I buy mineral washer or something? Should I try pressure washing it all first then soaking it in something? What's the best way to do all of this?
1952 Chevy 5 Window Restoration
Do you have a compressor? You don't need a big one, if you do you can get a small sand blaster from sears for $40.00 and use it to clean all your small parts. I use mine for all small parts
and they turned out great. Paul
Ex Hall Monitor
Ex Hall Monitor
I'm not saying it's the best but I use regular solvent (kerosene?) to clean parts. Mineral spirits would probably work.
Z
Z Offline
are you removing rust/paint or grease?oven cleaner works good for grease.i have a twenty gallon parts washer i keep a kerosine mix in for soaking.
box up all your "hard" metal parts and take them to a monument place and let them sand blast them for about 20 bucks, then take them back home, touch up the little spots they miss and then prime and paint. Any sheet metal you have blasted make sure folks know what they are doing but for the heavy stuff most anyone can do that.
I think I'll do what achipmunk said.. I don't really want to go and buy a bead blaster and a new compressor right now, so I boxed up everything to take to get sandblasted... it'll be a lot easier and cheaper smile
Put small parts that are rusty in white vinegar and let them sit for a day or two. They will have black crud on them when done and it washes right off to a clean piece of metal.
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
