Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Peggy M, 2-Ton, Jon G, Wickedbass, tclederman, Youngin' Tut 59), 42 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#21854 12/11/2002 3:26 AM
Help, i got a 51 1/2 ton
what engine do i have?
head # 3836848 gm5
block# k2233 (behind starter)
can someone help decifer this for me
#21855 12/11/2002 4:46 AM
Look at the letters and numbers just below and forward of the distributor.
#21856 12/11/2002 11:20 PM
ok all the info i got
3836848 on the head
3837004 on the block
k2255 stamped behind starter
also beneath both casting number is "GM5"
was told is could be either a 55-57 chev engine
or a gm from some year
is there a way to tell gm from chev
also anyone have the hp and torque on this thing
#21857 12/12/2002 3:23 AM
It's not a GMC, and it's probably a Chevy 235. HP is about 100-140 depending on who you believe and how you measure it. The head is the high compression 235 head. The '53 Corvette version produced 150 HP and 227 ft-lbs of torque with a more radical cam and triple sidedraft carbs.
Paint & Body Shop moderator
#21858 12/12/2002 4:48 AM
Junior Member
Junior Member
How do you know if The head is the high compression 235 head... Is it the GM#
Also...is there a difference between a blueflame 235 and any other 235s...
thanks..
#21859 12/12/2002 8:51 AM
Well, high compression is relative, I guess. The 3836848 head is the highest compression of all the 235 heads with the biggest valves and best flow of all of them. It's only 8:1. See casting numbers for more info. The list is not complete on the block castings. The Blueflame 235 is the car version with a fiber timing gear and hydraulic lifters and the Thriftmaster 235 is the truck version with aluminum timing gear and solid lifters. There is also a rare Corvette 235 with a hotter cam and sidedraft carbs. There is also an earlier splashoil 235 offered before 1953 that looks like a 216 and shares the dipper rods. It is referred to as the hi-torque or jobmaster 235.
#21860 12/13/2002 4:50 AM
Junior Member
Junior Member
1 Offline
Your block and head casting numbers match my 1956 thriftmaster 235. It is rated at 140 gross horsepower. 128 net horsepower according the spec. plate in my door frame. However, your casting date, K2255 is different from mine. K2255 translates to the to cast date November 22, 1955 (K=11th month= November, 22 is the day of the month. 55 is the year).
1956Chevy3100
