5 members (Bill Hanlon, Jman, Robert Crandall, Steelonsteel, Wally / Montana), 87 guests, and 3 robots.
Topics128,035
Posts1,055,556
#218464 10/25/2006 11:43 PM
Hi guys,
I'm doing a restoration on my 57 3100 and would like to find a replacement hood to save myself a ton of body work. I know that the hood for 1957 is slightly different from the 55 (2nd gen) and 56 due to the spears down each side. How about the 58 and 59? Is there much difference between them and the 57 besides the obvious emblems? Want to figure out my options before I head out to swap meets and salvage yards.
Thanks in advance. You guys are the best!
The '58/59 hood uses a different hinge, I'm not sure if they will directly interchange because of this. The 5-6-7 hoods use the same mounting, and will directly interchange.
Bill Burmeister
3B Offline
Hy guys, I believe the 58-59 hoods are longer, hope that helps.
the hoods are skinnier that's why they have different hinge points
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
That's what I was thinking, but wasn't sure. As I noted, though, '55-'57 are interchangeable, only the bumps on the top are different.
Bill Burmeister
That makes sense because of the duel headlights. Narrows the search down to strictly 57 if I want to keep the bumps or 55 56 if I don't. I appreciate everybody's advice.
Thanks so much
the 55-59 hood sizes are identical, including length and width - the hinge difference is on the firewall and the fact that the 58/9 hinges also bolt to the inner fender - length difference is in the frame to accomodate the splash pan below the grill
Hey Bill I thought that the 58 and 59 were different due to the Quad headlights.
But then again I have never really checked it out.
CLiff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
yer right Cliff!! I guess I mis-spoke ... cuz it was gettin dark and rainy so I didn't wanna go out and look grin mea culpa
I had a 59 hood sittin on the 57 panel for awhile cuz it was handy, w/ hinges attached, between 55 fenders that were just held on w/ a couple bungees - guess I didn't pay attention to the fit
so today I had a chance to do some checkin among the numerous hoods in the yard [make good covers for parts] - the early and late hoods are identical at the back, including the hinge mount points [on the hood] - they're also exactly the same length, but the front of the later hoods is 2" narrower than the early ones, with a subtle curve along the side to make up the difference
so the way to put the later hood on would be to put the whole 58/9 front clip on, which has other problems
