9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible),
125
0
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 24 Apprentice | | Apprentice Joined: Aug 2006 Posts: 24 | I plan on putting on a MII kit. I found one through Classic Performance it's $1899 for the one with bags. I've just started looking, Where is the best deal on one of these? And are there any out there I should avoid? Is there a big difference in the quality? Any of your experiences would add to mine. P.S. If you could convince me otherwise please do. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I used a heidts kit, (not the bags), disk to disk for something around 2500... works great...
| | | | | Joined: Aug 2006 Posts: 24 Apprentice | | Apprentice Joined: Aug 2006 Posts: 24 | Anyone used the Classic Performance? | | | | | Joined: May 2005 Posts: 20 Apprentice | | Apprentice Joined: May 2005 Posts: 20 | I literally JUST finished installing a Heidt's MII kit, and it was freaking great. the instructions were spot-on, and it seemed that they had worked out the bugs long ago! not sure about the C.P. version of the MII, but if it's like the Heidt's, should be easy. I'm not the world's best gearhead, but my buddy & me parked it under a tree, took off the old front end, and slowly put it all back together, with a little luck and a lot of measuring before welding or cutting, it went together great. the great thing is I bought the kit through Chevy Duty (rip) and the brake pads they sent were all messed up, and when I called Heidt's they didnt ask questions, they just sent out some new ones, along with some other stuff I was getting, even though I wasnt in their computer as a customer. very nice. good luck with the conversion and send some pix to the 'Bolt!
sure love my old Chevy.
| | | | | Joined: Sep 2006 Posts: 60 Member | | Member Joined: Sep 2006 Posts: 60 | The Heidt's is the top of line in comparison to the others. I have owned or helped to install that,Fatman,C.E. and R.B.s and others. The upper arm are a different type, once you align, you don't mess around again. If you have already planned to use the Heidt's and find the price agreeable, then I would not even bother with the rest. There is more info on Chevytalk, do a search if needed. Good luck to you. Jon | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | Crosleyfield hit on a good point....
ENSURE THAT YOUR MEASUREMENTS ARE CORRECT, DO NOT MEASURE ONLY TWICE.. MEASURE, REMEASURE AND MEASURE AGAIN.
Then have the welder measure it too...
| | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | hay i dont want to hijack you but do any of you have a coil over set up and is it better than the reg mustang 11
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | HEIDTS IS THE BEST GET THE SETUP FOR COILS WITH THE CONVERSION KIT FOR BAGS THEN IF YOU WANT TO TAKE OFF THE BAGS YOU WILL NOT HAVE TO CHANGE THE UPPER HATS. (THE UPPER HATS ARE THE PIECES THE UPPER A ARMS BOLT TO I BELIEVE THE BAGS ARE DIFFERENT THAN THE COILS) I USE HYDRO RAMS SO I USE THE COIL SET UP | | | | | Joined: Sep 2006 Posts: 60 Member | | Member Joined: Sep 2006 Posts: 60 | Robin, you are correct, CPP is a dist for TCI. TCI is good qual stuff, the support and printed matter are weak since their budget goes into pretty color ads and product development. Some parts are multi-application, but most guys can "make" them work. Still a different set-up than Heidt's. No matter the maker, measure 3 times, weld once. Jon | | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | Has anybody used the Jim Meyer frontend? It uses Camaro spindles. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I used the TCI kit,worked OK for me. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used TCI, parts were of good quality. Instructions stunk, not very clear. Also I had a problem with one part, returned it, took at least 2months to get another part from them. Numerous phone calls did not speed up the process. I would not use them again!!! | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 |
| | | | | Joined: Aug 2006 Posts: 24 Apprentice | | Apprentice Joined: Aug 2006 Posts: 24 | RB's and Chassis Eng offer a bolt on crossmember, they claim it is better than weld on for a +$200 more. Anyone know about these bolt on X members? Thanks for the help. | | |
