1 members (tclederman),
123
Mod | | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | i have a 51 chevy 3100 half ton truck with a 3 speed column shift i need to know the tranny type becaus i may need another one this one growls bad in low | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have an s/10 t/5, 5 speed with overdrive.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 |
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I could not find a specific designation, but the '51 trans looks very much like the '55-'66 SM318 internally. I know that most internal parts are availible for that one, some might interchange, such as the first/reverse slider and the couter shaft.
Bill Burmeister | | | | | Joined: Aug 2006 Posts: 65 Member | | Member Joined: Aug 2006 Posts: 65 | pushrod, assuming that you have the original tranny in your truck, chevy reffered to them simply as a synchomesh transmission. The serial number is located on the side of the case at the rear edge of the trans cover. for your model year, it should have a "J" (year designation) followed by "N" if it was built in Saginaw, "O" if built in Muncie or "P" if it was built in Toledo. Then it would have numbers which would designate the sequence number of the trans. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Pushrod,got a 3 speed tranny,52 closed drive shaft.give me a shout.the price is right
dan-pa
| | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | hey dan-pa sent you a pm,,, | | |
