Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Pre '68 Dave, 55shaker), 110 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
#216861 10/02/2006 10:58 PM
i have a 51 chevy 3100 half ton truck with a 3 speed column shift i need to know the tranny type becaus i may need another one this one growls bad in low
#216862 10/02/2006 11:36 PM
i have an s/10 t/5, 5 speed with overdrive.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#216863 10/03/2006 1:40 AM
The Ox has a 700R4
Another quality post.
Real Trucks Rattle
#216864 10/03/2006 2:32 AM
I could not find a specific designation, but the '51 trans looks very much like the '55-'66 SM318 internally. I know that most internal parts are availible for that one, some might interchange, such as the first/reverse slider and the couter shaft.
Bill Burmeister
#216865 10/03/2006 2:59 AM
pushrod, assuming that you have the original tranny in your truck, chevy reffered to them simply as a synchomesh transmission. The serial number is located on the side of the case at the rear edge of the trans cover. for your model year, it should have a "J" (year designation) followed by "N" if it was built in Saginaw, "O" if built in Muncie or "P" if it was built in Toledo. Then it would have numbers which would designate the sequence number of the trans.
#216866 10/04/2006 6:37 PM
Pushrod,got a 3 speed tranny,52 closed drive shaft.give me a shout.the price is right grin
dan-pa
#216867 10/04/2006 10:21 PM
hey dan-pa sent you a pm,,,
