Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Peggy M, 2-Ton, Jon G, Wickedbass, tclederman, Youngin' Tut 59), 42 guests, and 7 robots.
Topics128,010
Posts1,055,303
Members48,419
#216786 09/30/2006 11:02 PM
i heard that the 216 and the babbit 235 have steel piston's, is this true? i've never seen a steel piston eek
#216787 09/30/2006 11:44 PM
i've never heard of either motor having steel pistons. Every 216 that i've ever had had cast iron pistons. i know that some 235's had aluminum pistons.
#216788 09/30/2006 11:51 PM
wow;; cast iron, they must be heavy, no wonder i couldn't unstick the one on my 216,it must have been rusted right into the cylinder, thanks for the info,, ron
#216789 10/01/2006 2:17 AM
Ex Hall Monitor
Ex Hall Monitor
That's why you can't turn high RPMs with a babbetted engine. The inertia generated by the heavy pistons distorts the babbett material. Simply replacing the cast iron pistons with aluminum will allow you to turn significantly more RPM without hurting your engine.
#216790 10/02/2006 2:28 AM
Some of the 265 V-8s had iron pistons, too, mainly the '57s.
Bill Burmeister
#216791 10/02/2006 2:47 AM
Are the pistons being described in this thread truly cast iron, or are they cast steel.
I remember hearing about forged aluminum, cast aluminum, forged steel, but I don't know if I have read about cast iron.
Stuart
#216792 10/02/2006 3:59 AM
The way I understand it, they are cast iron. never heard of steel used for a piston, only rods and cranks. I suppose that someone might have made a steel piston, but it wasn't GM.
Bill Burmeister
#216793 10/02/2006 12:27 PM
the Chevrolet master parts catalog lists them as cast iron.
