1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#216613 09/28/2006 5:21 PM
Apprentice
Apprentice
I have a '49 1/2 ton that has a Harrison heater in it. It is not the fresh air heater that goes on the passenger side. I can't find any model number on the heater, other than the Harrison logo on the front. The round core in the heater leaks and my local radiator shop told me that it couldn't be fixed because the leak was down in where the tubing enters the core. I've been looking around for a core, but before I spend too much time, I am wondering if this is the right heater for this truck to begin with?? If not, what would it have probably had in it? (this truck was from GM Canada) If the correct heater, any suggestions on how to find a core or someone who might repair one?
Greg - 49 1/2 ton
Ex Hall Monitor
Ex Hall Monitor
I bought a correct, fully restored heater for my 38 coupe from this guy: Roger Kaster
E-mail Address(es):
[email protected]
I have no clue as to whether he's still in the restoration business or not or even if the e-mail addy is still good. It's worth a quick e-mail to see if he can help.
#216615 09/28/2006 10:05 PM
Sounds like you've got the standard heater for these old trucks. GOOD LUCK not spending a bunch on the heter core... I've finally relented to the $175 for a re-core and altho it makes me SICK that no-one is stepping up and making these heater cores, it IS what it is!
#216616 10/02/2006 12:34 PM
Apprentice
Apprentice
Thanks... since it sounds like this is the right heater, guess I will go after finding a core.
Greg - 49 1/2 ton
#216617 10/02/2006 12:41 PM
Greg,
does your heater motor stick through the firewall? If so, I think that it may be the older 48 style that I have only seen once. If your heater is the standard type "recirculating" heater, there is a thread on "OldGMCTrucks" that gives the name of a place in the northeast that has the cores. They are expensive though. My heater in my Canadian truck says GM on the logal and it is a recirculating heater.
1951 1 Ton Completed
Jim Carter sells the round recirulating heater cores new.
My wish is for an A/C package that don't require removal of my deluxe heater.
Mike Barnes
1950 GMC 1-ton pickup
#216619 10/02/2006 11:59 PM
Apprentice
Apprentice
The only thing that goes through the firewall are the two copper pipes to which the in and out hoses connect and two studs/bolts that have a wingnut on the engine side of the firewall. It has Harrison on the front on the door flap. On mine the bottom half of the round part is a door flap that you open up to let the heat/air out. From looking, it seems like these come in many shapes and sizes!
Greg - 49 1/2 ton
#216620 10/03/2006 12:26 AM
Apprentice
Apprentice
Found the parts online as recommended, but mine requires two halves that have to be soldered together... I think I'll inquire at a couple more local radiator shops about repair of mine before going that route. But thanks.. looks like I have some options.
Greg - 49 1/2 ton
