9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible), 158 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#216584 09/28/2006 2:55 AM
I'm going to have a couple complete 261 engines shipped across country. We're trying to decide on bolting them to a platform as they would sit in a truck or laying them left-side down. Any suggestions?
http://www.leonmack.com/
'48 Chevy 1/2 ton
'66 Volvo 122S 2-door
'68 Volvo 220
#216585 09/28/2006 3:06 PM
Ex Hall Monitor
Ex Hall Monitor
I've never really thought about it before. The only engines I've seen shipped (not many) were sitting upright on a pallet.
#216586 09/28/2006 3:45 PM
Drain all oils and fluids. I placed a 3/4 inch peice of plywood to the pallet for a solid floor, I shipped one sitting on the bellhousing side of the motor (fan blade in the air) and bolted it to the pallet that way. Then I made a wood frame around the pallet and then closed it in with cardboard. I threw a few handfulls of sawdust on the bottom to soak up any residual oils/fluids tha might leak out.
If I had to do it again I think I would weld up an engine cradle for it and ship it like the machine shops do for small blocks.
I also sent mine through a machine shop that I was aquainted with. They got a better shipping rate than I could on my own. Saved $100 or better. That is a pretty heavy motor to ship.
