10 members (Donf, Gdads51, Woogeroo, Jon G, DennisM, JoeDude, rfs56trk, Jaison, frogfarmer, Hotrod Lincoln),
164
Mod | | | Forums66 Topics128,035 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 9 Junior Member | | Junior Member Joined: Jul 2006 Posts: 9 | I JUST TOOK MY BED OFF THE FRAME AND THERE IS A CROSS BEAM STILL ATTACHED TO THE FRAME. IT LOOKS TO BE RIBETED ON THE FRAME. IS IT FACTORY OR CAN IT COME OFF? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's factory. Any special reason you need to take it off? You need as many of those crossmembers as possible for rigidity sake. People often torch them out or notch them without doing any other reinforcing and wonder why the frame twists and the truck handles like a wheelbarrow. Scott | | | | | Joined: Jul 2006 Posts: 9 Junior Member | | Junior Member Joined: Jul 2006 Posts: 9 | ITS ON TOP OF THE FRAME. DO I NEED TO LEAVE IT ALONE? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Do you have a picture? Usually anything rivotted is structural and not an attachment. Most dealers and aftermarket shops didn't rivot but rather bolted their stuff on, so I would say leave it if you can, Scott | | | | | Joined: Jul 2006 Posts: 9 Junior Member | | Junior Member Joined: Jul 2006 Posts: 9 | | | |
