3 members (GIJOE298, Peggy M, 1 invisible),
123
Mod | | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 3 Junior Member | | Junior Member Joined: Oct 2003 Posts: 3 | Were the 1955 2nd series 15 in. wheels six bolt? If not, when did chevy pickups come with 6-bolt, 15 in wheels? Question to my OCW Q&A column. Thought it best to ask yoou guys first. | | | | | Joined: Nov 1995 Posts: 5,722 24601 | | 24601 Joined: Nov 1995 Posts: 5,722 | Hey Tom! Welcome to the Stovebolt Page! Good to have you on board.
Should be someone along soon with the answer.
Best regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Tom,
My impression is that the 2nd series '55 up to '59 wheel stuff is virtually the same. If not, somebody please correct me. Anyway, my '59 wheels were 15" 6-bolt. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | MY 62 was 16X6bolt only assume they were stock. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 15" six bolt wheels were an option on 1/2 ton trucks for most, if not all, Advance-Design years (1947-1955).
I will post detailed information later tonight (option numbers, etc), if someone else does not post info right away. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | GM light trucks were 6 bolt from very early to sometime like the 70's at least - 15's were standard for the 55-9 1/2T trucks, with 16's available for heavier GVW's
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1949/50 (and maybe earlier), the Advance-Design Chevrolet 1/2 ton trucks' standard wheels/tires were 6.00-16, 6 ply on a 16x4.0 rim
In 1949/50 (and maybe earlier) the Advance-Design Chevrolet 1/2 ton trucks had three different 15" wheel/tire options: RPO 288B 6.70-15, 6 ply on a 15x5 rim RPO 273H 15"-6 ply on a 15x5.5 rim RPO 280F 15"-8 ply on a 15x5.5 rim
In 1954/55-1st, the Advance-Design Chevrolet 1/2 ton trucks' standard wheels/tires were 6.00-16, 6 ply on a 16x4.5 rim (6.50x16, 6ply on a 16x4.5 rim was available as a common option on the rear-only or on front and rear)
In 1954 the Advance-Design Chevrolet 1/2 ton trucks had one 15" wheel/tire option: RPO 273K 15"-6 ply on a 15x5.5 rim
Some, if not all, 1947-55 1/2 ton New Design GMC trucks also had 6-bolt 15" rims available, but I think they used a split rim. | | | | | Joined: Aug 2006 Posts: 65 Member | | Member Joined: Aug 2006 Posts: 65 | Hey, wait a minute. Tom Brownell? THE Tom Brownell? The Tom Brownell that wrote the book "How to Restore Your Chevrolet Pickup"? The very book that goes under my pillow every night when i go to bed? Whoa dude, what an honor it is to post something on the same site as you! The book is awesome! If anybody on this site has not looked at or does not have a copy of this book, friendly word of advise, go buy a copy! If you're not the real Tom Brownell, two things: (1) You've busted my bubble impersonating the real Tom Brownell and (2) change your name to something else and quit pretending to be Tom Brownell. | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Hi Tom, Welcome! - The first 15" wheel I know of being used by Chev. was the 15" artillery style wheel used as standard equipment on the 1937-42 3/4-ton pickups. This same 15" wheel was also an option on the 1/2-tons in those same years. So I would say the first 15" wheel came way back in 1937! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think every pre '72 1/2 ton truck, regardless of wheel size, was a 6 bolt pattern. Obviously there were many different wheel configurations over the years, Scott | | | | | Joined: Aug 2006 Posts: 65 Member | | Member Joined: Aug 2006 Posts: 65 | I just looked in the Chevrolet Master Parts & Accessory Catalog and the first reference to 15" wheels goes back to 1935 (appears to be cars and maybe trucks) and 1939 was the first reference i saw to "commercial" vehicles. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Are those all 6 bolt 15" wheels?
There is a 15" 6 ply (15x5.5 "short spoke steel disc") optional wheel listed for Light Delivery Trucks in the 1939 Chevrolet Salesman Truck Data Book: "low pressure balloons for easy ride and greater capacity"
A 5.50-18 tire option was also available for muddy roads.
The same 15" wheel (artillery style) is shown for the 3/4 ton truck. Maybe someone who has a 30s truck can confirm that the light duty truck (1/2 ton) used 6 or 8 bolt wheels. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Hey, Kens 50 PU, I was thinking the same thing! I show a 15" option for '37 in the standard catalog, I do know that the '55 2nd came standard with 4 ply 6.70x15 tires, and that 15" 6 lug wheels were used on all 1/2 tons to '70, 4x4 1/2 tons to '87/'91 on Blazer/Suburban.
Bill Burmeister | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Yes, the '37-'42 15"x5-1/2" artillery wheels were 6-bolt. 3/4-tons weren't 8-bolt until '46. | | | | | Joined: Aug 2006 Posts: 65 Member | | Member Joined: Aug 2006 Posts: 65 | tclederman, in response to your question above about "were they 6 bolt?", the catalog did not say. it gave diameter, width and offset, but not bolt pattern. | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Kens 50 PU -- It is THE Tom Brownell. Not only does he stop by regularly here, he sent in a Gallery submission for his son Anthony's dump truck! When he first sent it in, I had the same re-action as you ... "are you THE Tom B?" Felt honored, also His book is GREAT. We hope to get a few for the IRWPI contest this year. Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Oct 2003 Posts: 3 Junior Member | | Junior Member Joined: Oct 2003 Posts: 3 | Thanks for the held and welcome comments guys and Peggy. A feature on the Stovebolt Page will appear in Vintage Truck, Dec. 06 issue. | | |
