2 members (baldeagle, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#216021 09/18/2006 10:27 PM
Junior Member
Junior Member
I JUST TOOK MY BED OFF THE FRAME AND THERE IS A CROSS BEAM STILL ATTACHED TO THE FRAME. IT LOOKS TO BE RIBETED ON THE FRAME. IS IT FACTORY OR CAN IT COME OFF?
#216022 09/18/2006 10:36 PM
Quote
Ah, the dreaded frog welding!
You're probably speaking of the transmission crossmember, which should stay unless you're planning on switching to a different tranny.
Brian
#216023 09/18/2006 11:19 PM
Junior Member
Junior Member
AND THIS WOULD BE ON THE TOP OF THE FRAME RIGHT BEHIND THE CAB
#216024 09/19/2006 12:21 PM
Socket Breaker
Socket Breaker
PLEASE STOP SHOUTING.
grin
-W
