1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | Greetings, I'm new here to the forum and to the Chevy truck project. Have a '51 1/2 ton 5 window project. Rebuilt a 1954 262 coupled to a 1986 T-5 tranny with a 1983 Camero rear end with 373's. Fenton exhaust with Offenhauser intake set up with two 2 barrel Carter/Webers, question - what is the best way to finish off the project with the fuel line from the fuel pump to the carbs? I would like a clean set up but with a little flair. Any ideas? Stainless? Lloyd from Washington | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Why not some chrome steel flared lines? | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Stainless lines look quite nice when properly bent and polished. I have also seen heat shrink tubing used over steel lines.(the kind you use for electrical wiring repair). It can be purchased by the foot at an electrical supply store in many colors.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | A nice shiny fuel block with a couple of braided stainless lines and the red/blue anodized swivel fittings looks sort of neat.
Stuart | | | | | Joined: May 2004 Posts: 351 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 351 | Where do you buy SS fuel lines> Any chain parts stores? | | |
