| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | Are Bilstein shocks worth the money? I'm a daily driver, put 30k on a set of NAPA, they're junk now.
Where can I find a source for Teflon leaf spring liner material?
As always, thanks to one and all, Cosmo.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | i put kyb shocks on my van.it surpised me how much better it rode.
64 c10 89 rs 62 econoline 50 ford coupe
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | The teflon at a hardware store ,cut your own.or a spring shop/ the shocks life is around 25 to 30,000 miles.What about your warrenty???.
dan-pa
| | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | McMaster sells teflon film from .002" to 1/8" thick. Used it once, works great. See item #8569K28 for a starter. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I put Monrow Sensitrac on my front. They helped quite a bit, but the previous were so old I don't think they were doing anything- so any change would have been an improvement.
What is the purpose of the Teflon? | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | On the teflon bushings, go to any 4x4 website and look up suspension parts for newer model 4x4 trucks. Get the name of a bushing manufacturer and e-mail them the length and diameter's you need. As for shocks I am a an old monroe fan but on the imports i use kyb.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | If you can find a kid's old "Magic Carpet" the roll up plastic toboggan they slide on snow with. It is perfect. Cut the strips you want from it. | | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Speedway motors has the spring liner, do a search for Poly-liner. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | be aware that if you but anything between the spring that it will raise the height of the truck over all. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | Looks like Speedway is a winner, thanks, Joe H. Duly noted, We b OLD, did not think of that but I'm digging stock height, so + 1/2" or so ain't no biggy. Thanks to all good luck w/ your projects.
| | | | | Joined: Nov 1995 Posts: 5,714 62401 | | 62401 Joined: Nov 1995 Posts: 5,714 | Cosmo -- For what its worth, I ran Bilsteins on my BMW and my '59 VW -- loved 'em and thought they were worth it. John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
