| | | Forums66 Topics128,028 Posts1,055,413 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 17 Junior Member | | Junior Member Joined: Jul 2006 Posts: 17 | i looked at some of the identfy your truck post and orther site it seem they all whant a vin ive found seral number and everything else but no vin serirl 3c91534604719a engine c716212 style c91534 paint 500/ it is a made in canada and is beleived to be a 65 gmc ive checked all the loction showed on the site were plates could be and this is all i come with did canada use serial num instead of vin thank you
You have to stand for somthing or you will fall for anything
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I had a 1966 chevrolet c-20.The vin was at the top of the drivers side door jam.Hope this helps you find it. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Madtrapper,
VIN numbers as we know them were not used until about 1978 or so...
Prior to that, the serial # and sometimes, the engine number were used for the title.
For my 46, my state added zeros or the letter O on the front end of the serial number to get the correct number of characters for a modern day VIN. The number plate on the truck remains unchanged. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's been much animated discussion of VIN's here - these trucks did have vin's, just not the type currently in use - engine numbers weren't used anywhere past about 54 - your CDN title should have a box that's labeled "VIN/Serial#" and to the MV folks, they terms are interchangeable for things older than 80 or so
the CDN vin conventions were different than the US ones, and GMC is different than Chev, and you'll not find any site that has any real info about them, especially GMC - your # 3c91534604719a is your vin - not sure about the 60's breakdowns, but the 3c should be the year [63?], the 9153 prolly indicates the model/weight, 4 the style [pu?] and the rest may show engine/trans and is the production sequence#, which is the real serial#
Bill | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Bow tie, I had everone at the bolt telling me where to find it. It was on the driver side top door jam but darned hard to see. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | HY madtrapper, your serial number breaks down as follows 3-model year 1963 C-Conventional cab 9- G.M.C. 15-series 34-model 04719-sequential vehicle number A-6000lb. or less G.V.W. hope that helps. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Glad you found it,sometimes they can be very hard to see. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
