| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 17 Junior Member | | Junior Member Joined: Jul 2006 Posts: 17 | hey i have 65 GMC im not sure what it supposed to look like . i have checked trew the gallary and orther web site from what i can tell there the same except the front grill and the chev had more chrome. i likr the chrome on the chev but prefere my grill how madd does it make bolters if i mix them up.please let me know if there are any bigg deff and where i could get orginal pic of the gmc And i thought i was hving carb pro but know im not sure how bad does not having a mulfer efect these old truck to they rely on back pressur but god does she sound good i named towmator of of cars how do put pic of truck under name
You have to stand for somthing or you will fall for anything
| | | | | Joined: Jul 2006 Posts: 17 Junior Member | | Junior Member Joined: Jul 2006 Posts: 17 | hey it me again can i rely on the oilbath filter or do ineed to upgrade iit will see more gravel then pavemeant and we have a lot bugs up here GRASSHOPER THANK
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | GMCs were available with chrome grilles. Check out the picture here 6066 GMC site Lots of other info on your truck there too. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Oil bath should work just fine, they were eliminated because they were a pain in the butt. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Asking the oil bath or not oil bath question will usually start a long and acrimonious thread here. I'll simply say I disagree with Gazim on both points.
| | | | | Joined: Jul 2006 Posts: 17 Junior Member | | Junior Member Joined: Jul 2006 Posts: 17 | is there a filter that fit right in to the cainseter or would u need to change can i put those v powered spurk plug in or do the run to hot flat 6
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I went to the parts store with my clean air filter housing & found a dry element that fit perfectly. I don't have the part number right off hand but it's a Wix filter. Mine is a 38 216 so I don't know if the same filter would work in your truck's housing anyway.
| | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | GMC had chrome grills too as mentioned. I like the looks of a GMC grill with the four headlight system. I am a fan of paper filters over oil especially if I am going to use my truck, not restore it. Easy maintenance and practical is the only way to go. | | |
