2 members (Otto Skorzeny, joe apple), 64 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#214083 08/19/2006 9:28 PM
Junior Member
Junior Member
hey
i have 65 GMC im not sure what it supposed to
look like . i have checked trew the gallary and orther web site from what i can tell there the same except the front grill and the chev had more chrome. i likr the chrome on the chev but prefere my grill how madd does it make bolters if i mix them up.please let me know if there are any bigg deff and where i could get orginal pic of the gmc
And i thought i was hving carb pro but know im not sure how bad does not having a mulfer efect these old truck to they rely on back pressur
but god does she sound good
i named towmator of of cars
how do put pic of truck under name
You have to stand for somthing or you will fall for anything
#214084 08/19/2006 10:03 PM
Junior Member
Junior Member
hey it me again can i rely on the oilbath filter or do ineed to upgrade
iit will see more gravel then pavemeant
and we have a lot bugs up here GRASSHOPER
THANK
#214085 08/19/2006 10:09 PM
GMCs were available with chrome grilles. Check out the picture here 6066 GMC site
Lots of other info on your truck there too.
#214086 08/19/2006 10:24 PM
Oil bath should work just fine, they were eliminated because they were a pain in the butt.
#214087 08/20/2006 1:42 AM
Ex Hall Monitor
Ex Hall Monitor
Asking the oil bath or not oil bath question will usually start a long and acrimonious thread here. I'll simply say I disagree with Gazim on both points. grin
#214088 08/20/2006 5:20 PM
Junior Member
Junior Member
is there a filter that fit right in to the cainseter
or would u need to change
can i put those v powered spurk plug in or do the run to hot flat 6
#214089 08/20/2006 8:47 PM
Ex Hall Monitor
Ex Hall Monitor
I went to the parts store with my clean air filter housing & found a dry element that fit perfectly. I don't have the part number right off hand but it's a Wix filter. Mine is a 38 216 so I don't know if the same filter would work in your truck's housing anyway.
#214090 08/20/2006 11:01 PM
GMC had chrome grills too as mentioned. I like the looks of a GMC grill with the four headlight system. I am a fan of paper filters over oil especially if I am going to use my truck, not restore it. Easy maintenance and practical is the only way to go.
1965 Chevy C-10 Longbed Stepside
