8 members (Wally / Montana, Mike Burns, HandyAndy, Patina 54, Cosmo, RoadsScholar, 2 invisible),
199
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21403 03/24/2004 4:14 AM | Joined: Feb 2004 Posts: 8 Member | | Member Joined: Feb 2004 Posts: 8 | Can anybody help me out there on some questions I have on my pickup I just bought, 70 C-10. It now has 6 cylinder with 3 speed on the colunmn. No disk brakes or power steering. I have located a 1976 chevy with a 350 engine, auto transmission, Power steering and disk brakes. Will all the above swap into a 70 pickup with little or no problems? What about motor and transmission mounts-crossmembers? Thanks any help would be most helpful!! | | |
#21404 03/24/2004 6:54 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The bad news is you will probably need motor mounts, cross memeber, and rearend from the 76. The rearend you've got now is probably a 4.56. If you like being first to the next light, and filling up every other light not a problem. So look at the 76 rearend and see what it's going to take to swap it. Check the brake booster to see how it is mounted too. The good news is the complete front end should swap over without too much trouble. Drilling a couple holes might be all that is required. my .02 worth.
Larry 68 C20 327 daily driver 63 C20 292 Camper truck 65 C10 ? Custom Cab AC,PB,PS,$flasher
I don't own a vehicle that isn't old enough to drink. | | |
#21405 03/25/2004 2:40 PM | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | I also have a 70 equipped same way. You have most everything you'll need on the newer model. You can swap out the entire front end assemble and bolt it on to you 70.
What your short will be a automatic steering column (unless you use floor shifter), motor mounts, possible tranny kick down assembly from the older style, and depending on the application (tranny, and it's taillength) you may or may not need a driveshaft. It's not too bad, just a few tidbits to address, but not to bad a swap.
Bill | | |
#21406 03/25/2004 2:42 PM | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | Oh yeah, if your's is a basic model, it probably came with 3.73 gears, unless the glovebox shows an option. Gers aren't too bad then, but you will wind up without an overdrive unit.
Bill | | |
