Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Wally / Montana, farmallb, Peggy M, jasrking, 2-Ton, 1 invisible), 36 guests, and 0 robots.
Topics128,010
Posts1,055,299
Members48,419
#213791 08/16/2006 4:35 AM
What is the typical size and thread of the wheel studs on a stovebolt? Did GMC ever use bigger ones?
#213792 08/16/2006 11:50 PM
3B Offline
Hy bigbadswingdaddy, what size of truck are you asking about?
#213793 08/17/2006 12:10 AM
1/2 ton or 3/4 ton. Mine is a 6 lug 3/4 ton 1940 gmc. i was wondering if it would make a difference with the stock wheels if they were bigger.
#213794 08/18/2006 1:39 AM
Typically, pre '70 1/2 tons had 7/16" studs, with 3/4 ton having 1/2" and 1 ton with 9/16". It can make a difference with the wheels if the studs are larger in diameter, thenut seat may not fit correctly on the wheel, and will give an incorrect torque reading. The lug nut seat can be modified with a 60 degree countersink bit, you just slowly machine the seat to the correct size. I have done this on the Blazer ralleys that I have on my '55, no problems at all. I had to do it beacause I installed 1/2" studs in place of 7/16". The same procedure can be used to repair damaged lug nut seats too.
Bill Burmeister
