2 members (Rich'sToys, dt235sd), 76 guests, and 0 robots.
Topics128,049
Posts1,055,740
#213500 03/06/2007 9:25 PM
My 65 C-10 has been upgraded to disc brakes and power steering by a previous owner. My problem is I can't tell where the later model parts end, and the original parts begin. My front crossmember has three bolts holding it to the frame on each side, and the steering box fits to the original steering shaft without modifications. Any help would be greatly appreciated.
#213501 03/07/2007 12:16 AM
Does it look like he swapped out the entire crossmember? That is the easy swap.
Fred
52 3600
69 C-10
#213502 03/07/2007 12:29 AM
3 bolts?? It should have about 14 IIRC. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#213503 03/07/2007 6:38 PM
I think the whole crossmember was swapped, i can't really tell though, because I've never seen what one looks like originally, and the lack of a sway bar threw me off too.
#213504 03/07/2007 7:56 PM
Eric, it can be swapped over to discs by swapping crossmembers or just the A-arms/spindles/rotors can be swapped . Does it drive OK? Brian
#213505 03/08/2007 3:38 AM
Right now its stripped down to a bare frame, because I'm doing a total resto, if memeory serves me correctly, it rode and drove pretty good, but it is in need of new bushings and other parts, and in other areas, the PO's work wasn't too sporty (rear end with no mounting brackets, just welded to the U-bolts, and ugly welds at that) and I need to know what to buy parts for.. I'll post some pics tomorrow so ya'll can see what I'm dealing with. Thanks so much for your help, I really appreciate it.
#213506 03/08/2007 5:26 AM
Junior Member
Junior Member
1 Offline
When i built my truck i used a complete front end out of a 1986 chevrolet pickup.
#213507 03/08/2007 11:25 PM
I put parts of a 84 in mine. Swapped out the spindles, ball joints and tie rods. Everything else is 65. My truck doesn't have a swaybar from the factory.
1965 Chevy C-10 Longbed Stepside
#213508 03/21/2007 7:24 PM
I have an 80 model truck that I am going to use the rearend from. Would it be best to go ahead and use the whole front suspension as well? This way I would know exactly what I have under there and would know exactly what to get parts for
#213509 03/21/2007 7:48 PM
Use 'em if ya got 'em Eric. That would keep it simple & easy to remember. If you want the swaybar, its real easy to add on. Just a matter of drilling the holes for the bushing clamps. Do you have any pics of your build?
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
#213510 03/22/2007 2:54 PM
Right now its completely disassembled. I had taken a couple dozen photos of my tear down, but a week later my computer crashed and I lost them all. I'm going to take a bunch more so I can see how my everything looks before and after.
