1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | I wuz returning home and the downtown was blocked off for fireworks so I had to wait in a long lineup to go home. While in that lineup so the police could verify I lived there on a steep uphill road where I was going 4-5' every 10 minutes smoke started to come out the back sides but not on the tailpipes. I stopped the truck, flipped open the hood and yelled, "That's it!". Needless to say the lineup got all messed up.
Do ya think the smoke was from the gear oil or the engine. Both were hot. I'm all worried now that I way-overheated it and damaged something. The cops and everyone were asking me what's wrong with the truck and I said "Who's the idiot who decided to put the lineup on a hill...and what's taking so long?!!!" I told them flat out that the truck was not designed to move 6" a minute on an incline. Sorry if I sound mad.... | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Petty typical. I find that police and construction crews put more thought into their morning Tim Horton's order (Krispy Creme for those south of the border) than they put into traffic flow around work sites/road closures.
I suppose this little diatribe belongs in the Greasy spoon, but the post set me off!
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | It happens to the best of us.Why is your valve pan leaking anyway.Lets get that stovebolt perking.No excuse for that crap
dan-pa
| | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | I'm not sure I understand the previous post.
So I've been driving my truck for a week since the smoke and I've noticed that pulling away in 1st gear the truck tends to shudder unless I rev high. The whole truck shakes. My father believe that I overheated the clutch and there was some old oil in there. So, have I ruined my clutch? There is only minor slippage in 1st gear and the shudder. There doesn't seem to be any loss of oil but it does seem to be darker. I noticed the radiator fluid had gotten rusty coloured so I flushed and cleaned it out. Any thoughts? | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | If you used your clutch a lot on that hill,to keep from going backwards, there is a good chance that you glaxed it. Don't know if you can fix it unless you replace the clutch plate and resurface the pressureplate. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The smell from a burning clutch is is about the same as burning brakes, if that was the white smoke. You will probably have to replace the clutch disc, if nothing else. You may be able to drive it for a while if you are really light on the throttle and avoid hills.
One should always use the parking brake when starting on a hill to prevent excessive clutch wear. | | | | | Joined: Jul 2002 Posts: 59 Member | | Member Joined: Jul 2002 Posts: 59 | If the shutter is from the clutch, which is likely, then you might try the method I used to cure the shutter on an old truck I once had.
I tied an old tire to my front bumber and eased the front end of the truck up to a large tree in my yard. I then slowly let out the clutch to cause it to slip. I don't know if this made the whole clutch glazed or wore off the glazed areas of the cluth, but it cured my shutter problems. 72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | why not just use the break pedal or the e-brake . Just smoke the clutch.put the pedal to the metal.a few time it should be fine or its clutch replacment time.clutch should last 90,000 mi +++++.depends on the driver.NAPA has your parts if need be.maybe a clutch adjustment will solve your problem
dan-pa
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Don't ride your clutch when you are on an incline. There is no reason why your truck can't handle a trafic jam.
delete my account and pictures
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 1951 3800 Be the change you want to see. -hotshoe
