6 members (FAST55, mick53, 50Chevy3100, baldeagle, Donf, TUTS 59), 64 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#213027 08/05/2006 2:54 AM
I am about to move onto my cab which needs several patch panels. Inner and outer corners. Floor patches (both sides) and inner door patches. (Possibly lower cowl as well)
Whose patch panels are the best fit/quality?
Rich
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
#213028 08/05/2006 2:58 AM
Hey, why don't you order some and let us know!! We would like to have some feed back too!!
#213029 08/05/2006 5:50 AM
I think you'll find most of them are all made in the same place. The question is who do you most like to deal with. Opinions vary there.
#213030 08/05/2006 6:05 AM
regardless of who you order from be sure to check the package as soon as it comes. If damaged be sure you keep the box etc. I just received a patch panel from Classic Parts (my first ever order from them) and when I opened it it was bent. You can tell by looking at the box. I called Classic Parts and they are shipping me a new one and contacting UPS.....which will in turn contact me. Just FYI (for your information)
#213031 08/05/2006 6:24 PM
I think I will go with Classic Parts. I have had very good luck with them in the past for other parts. They are typically priced competitively as well.
Rich
1953 3/4-Ton Chevy
More pix
RB53
#213032 08/06/2006 6:04 PM
You didn't mention what you were working on, but I really like Goodmark. I have ordered a couple pieces from them and they are very nice. However they do not carry parts for AD trucks.
#213033 08/07/2006 4:42 AM
I live near Grumpy's and went over there to look at them before I bought them. I liked them so I bought them. I ended up doing the right floor / toe board / right lower outer and inner cowl. Left back cab corner / lower left outer cowl. All of the pieces fit great. A couple of words of advice ...
1. Cut the patch panel to fit the area you are going to replace.
2. If you do the outer cowls. Make sure that you maintain the correct dimension across the door. I didn't and now I have to cut them back out.
#213034 08/07/2006 11:35 AM
Chev235,
That is too bad about the cowls. Thanks for the advice.
This is for my 53 3600. I was grinding off all the bondo yesterday. The corners are in much better shape than I thought. Just the very bottom needs to be replaced. I will cut the patch to fit the need.
The inside of the rockers doesn't look as good as I hoped. a few rot spots around the rear body supports. Not terrible I can patch that with sheetmetal.
Thanks for the help.
Rich
1953 3/4-Ton Chevy
More pix
RB53
#213035 08/09/2006 1:58 AM
I think you are talking about pieces that are compound curved but for relatively flat places you can cut pieces out of old car hoods. Cheap material.
I like old trucks
