6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
#212914 08/03/2006 4:36 PM
Hello,
I want to replace the slip joint packing at the collar on the torque tube housing. I did this about 5 years ago and recently it has begun to leak again. Is there a better way to seal this than just the corking? It seems the seal should have held up longer than it has since the last time I replaced it. All responses are appreciated.
Thanks!
1948 AD Pickup
#212915 08/03/2006 4:58 PM
You might want to try an oil resistant "O" ring. Use the cork ring for sizing. I ran one for a long time on my truck.
Joe smile
#212916 08/03/2006 5:39 PM
Hi 6cylindersovertexas,
That's a good idea! As soon as I get the old cork out, I'll go shopping.
Thanks!
1948 AD Pickup
#212917 08/03/2006 6:53 PM
No doubt that it's best to do the job properly, using the neoprene ring between the two flat metal washers, but in a pinch, you can unscrew the collar and add one or two turns of well greased bailer twine. Its a quick temporary fix and you don't have to split the U-joint to do it.
#212918 08/04/2006 12:40 AM
Now that's a handy little idea fredstev. Duct tape and bailing twine and bailing wire belong in every emergency tool kit!
1948 AD Pickup
#212919 08/04/2006 1:59 AM
Quote
Coat hangers - you forgot coat hangers. And the hangers that weren't painted also made great welding rod if you had a torch.
#212920 08/04/2006 6:36 AM
The link below is for the Filling Station in Lebanon OR. They have the parts and instructions you need to install an O ring instead of the cork seal.
www.fillingstation.com
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#212921 08/04/2006 5:16 PM
I've bought two sets of ball housing seals and both were rubber. The smaller is round and flat and the larger which goes around the ball housing is bevelled. They work fine. I did use the flat thin washers on either side of the smaller one which goes at the end.
Another thing is that if you get leakage from the big collar you can loosen the four bolts and remove one of the cardboard shims.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#212922 08/04/2006 11:24 PM
American Classics has the rubber one also I believe.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
