| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | In the process of getting my 56 3100 roadworthy. Put new brake cylinders and brakes on each corner and got a rebuild kit for the master. Much to my surprise, the master is nothing like the Truck Shop Manual! What I found was a master cylinder cast all one piece with a yoke to pivot the brake pedal. One side says Delco Moraine Products, the other side has the number 5454530 cast on and 117 stamped on. This look familiar to anyone? The first of probably what will be many questions. Thanks a lot in advance. Put some pics on http://www.cardomain.com/ride/2412127/2 | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Yep, that one looks just like mine, if I remember correctly. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | nothing like? what shop manual ya lookin at? in the brake section there's a figure showing "main cylinder, typical" - means not exactly as shown - the 55 manual doesn't show the yoke [fig.4], 57 does [fig.6], maybe the 56 manual is the same as the 55, but all TaskForce master cyls look just like what you've pictured and welcome to the garage Fred!! Bill | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | I just completed installing some new wheel Cylinders for my front brakes. I had replaced my Master Cylinder just three or four months ago. I thought all task force master cylinders were about the same? No matter.. Its nice to not have the Bolt Pull to the left (leak in the Lt. wheel cyl) when you are trying to slow down that much "IRON" Welcome to the StoveBolt Page Cliff59 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Like red58 said, "main cylider, typical". GM just used a picture that shows the breakdown of the parts, you'll probably find the same pic in manuals back to the '40's trucks and cars. The TF masters are the same for all years, exept for 1 1/2 ton and up and the forward controls. The 1 1/2 ton used a larger bore, the forward control models had a completly different casting. The parts breakdown is the same though.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | Thanks, all, for the input. It settled me down to the point I can get back to work on this. Going to the pros is the best way to get an answer (and piece of mind). | | |
