6 members (Jay R, TUTS 59, Otto Skorzeny, kades51, Cosmo, treegrower), 49 guests, and 2 robots.
Topics128,023
Posts1,055,365
Members48,420
#212442 07/24/2006 3:25 PM
I have 66 2wd drive long bed. I bought a 61 4X4 frame complete with the drivetrain. The question I have is will the 61 4X4 drivetrain bolt onto under the 66 frame. Reason I'm ask is the frame on the 61 is rusted out.
#212443 07/24/2006 9:50 PM
Riding in the Passing Lane
The 60-62 & 63-66 frames were completly different on 2 wheel drive. Im don,t know where the 4x4 falls in but I have my doughts.
1972 Chevy c10 Cheyenne Super
#212444 07/25/2006 1:46 AM
my 61 4x4 and my dad's 65 4x4 frames are relatively similar. I have no idea about bolting the 4x4 hardware onto a 4x2 frame though. It probably won't be easy.
#212445 07/25/2006 4:00 AM
No, a 2WD and a 4WD frame are completely different. A 2WD has a series of bends in it with coil spring rear suspension where-as the 4WD frame is a straight ladder type frame for leaves. I'm building a '63 K20 now and it had a rusty frame too. I bought a 2WD for it's body and considered using it's frame also. Once I had the two frames stripped bare, I could see that wasn't going to happen. I then repaired my 4WD frame instead,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#212446 07/25/2006 4:09 PM
my local 67-72 truck guru says 4x4 frames 60-72 were the same ladder type w/leafs fr & rear,,if both were 4wd it would work. my assembly manual show the 4wd frames 60-66 to at least be very similar,if not the same. 2wd is another story,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#212447 07/28/2006 7:25 AM
Continuing this same discussion... let's assume his 66 body is already on a 4wd frame...(in my case a 65 with 4wd under it) and put on a newer 4wd frame... like an 88 or newer Chevy with IFS... is this any easier or would this be near impossible also?
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
#212448 07/29/2006 2:56 PM
I once got the bright idea of converting a 69 C30 to a 4x4 using my rotted out 72 K20 drive line. Trust me the frames are not the same. Now I have seen some trick 4x4's out there where a guy put leaf springs and the axle under his 64 1/2 ton short bed. He added longer rear springs to even out the height. Anything is possible. Just depends on how much fabricating you want to do. It's not a bolt in job.
As far as Bowtie65's question. I have wondered the same. If the newer chassis is straight or nearly straight where the cab sets on, I am sure it could. I know 73-87 frames raise up under the seat area of the cab so 60-66 cabs don't sit right on that. (Last weeks lesson learned)
1965 Chevy C-10 Longbed Stepside
#212449 07/29/2006 3:29 PM
kruzeag,,the C30 was a different animal back then,, they were real one tons,heavy thick channel frame w/leaf rear springs,if you had had a 3/4 ton or less it woulda worked,,I know a fella has a 64-6 swb GMC on a mid 80s 4x4-there is a drop in the frame behind the cab,,he used body lift spacers to mount cab. It is not real pretty but evidently works. the 88-up frames are flat but not sure how they work out. for me personally a 4x4 must have a solid front axle tho,,brian
#212450 07/30/2006 6:04 PM
Brian, Depends on what you want it for. Hard core four wheelin' needs a straight axle, a 4x4 to get through the snow to get to work, IFS is fine. IFS rides better the rest of the time.
The C30 4x4 swap worked. It was a great looking truck when it was together. Just a lot of work for what I ended up with. Shoulda kept it. frown
#212451 07/30/2006 6:25 PM
that c30 4x4 sounds like a mean truck,,brian
