0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | I'm trying to fabricate a mount hanger sorta thing, and I need to put a few holes in the "band" part of a hose clamp. Well I bought one, and tried to drill through it, no success. Tried to hit a nail through it, no success. Even tried to use a soldering iron to heat it up and hit a nail through it. No success.
This is a really thin hose clamp, so what should I use that will work to put a hole through it?
Thanks guys | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Hey guy try putting it on a piece of hard wood and punching thru it with a punch. Sharpen it nice and pointy on the grinder first. Lothar | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What're you trying to hang? Those clamps are made from some tough material, you may need to check the projest metal section at the hardware store or farm store to get some thing that can be bent/drilled to make a hanger. If you a need to drill the clamp, try cobalt bits, they're more expensive, but they wil go through about anything.
Bill Burmeister | | | | | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Heat it with a propane torch.It should be easy to punch through then.
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | or get one of those plumber type hangers, not sure what you call them, they already have little holes in them,,not a clamp but you could probably put a small bolt thru them,, I used them on my rear lic plate to hang the topper plate, check my website, I cant for some reason post it here by its self Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Well I tried punching through to the wood, and ended up with a bunch of broken nails.
Okay, here's what I did. I had a shaft radio, and I cut the dash for a DIN style rectanglar radio (slide in). Well the old shaft radio had a mounting bracket that held it up, so to keep the radio level.
On this new one, it's a totally different shape, so the mounting bracket won't work. I was gonna try to use a hose clamp and "hang" it from above, to make it level.
Don't have a torch, but I've got a punch, I'll try that. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I had the same thing with an underdash unit in my '53. I had a roll of the plumber stuff Joker is talking about. Used it as a ground aswell. Its just a band with holes punched in it. Should be able to find it at any hardware store. Good Luck. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | HardyRestoration, If you can't punch, and you can't drill, the next option would be to GRIND! A little Dremel with a stone or carbide burr would buzz right through that sucka...I think! Stuart | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Hardy go to the hardware store and get a concrete nail. They are cheep and will punch throu it. | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Yep, use that stuuf that Joker and Colin are talking about. Save yourself some aggravation. It's inexpensive, I believe. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Plumber's strap or look in the metals section at your hardware store. You can find flat bar with holes in it. Cut it to length, bend as required. Sounds like you are working for the hose clamp, rather than it working for you. I believe it is made out of spring steel. Get something made out of mild steel so that you can work it. That spring steel has already been worked so it is REALLY hard to work it more, as you've found out.
Bill | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Joker,Colin the plumber type or plumber stuff is called plumbers tape. Realy good stuff for radio support brackets. They use to send you a 10" piece with the radio.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's called "perforated, galvanized PIPE STRAP" , and no decent shop is complete without a roll on the pegboard Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | thats it,, get you some...........I have some but you are to far away to throw it to you This would work for sure check it out Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Guys, I don't know what I would do without you Thanks! | | | | | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | you would probably lose an eye.
| | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | lol, that's ironic...i had to have surgery when i last worked on my truck cause i got metal nail bits in my eye  yum! | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I got too close to some ragged sheet metal as I was useing the air chisel to cut out the old cab corner. Consequently I ended up going to get stitches.The wait at the hospital was so long (4 Hours),that when they removed them 2 weeks later ,the cut simply opened right up.Then it just closed up on its own eventually,next time I just won't bother going.Didn't my truck know ,I was just trying to help it?  | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | super glue works pretty good at sealing up some cuts,,beats the wait at the ER,,brian | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Joker-where ya gonna find a screw to fit THAT hole?? Speed | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | If all else fails a good heavy duty zip tie like you use to tie wiring works wonders. | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Duct tape is the only way to go. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Amputation will solve all of your medical problems.... Including headaches.. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | Well to follow up this post, thought I'd throw in the classic story of what happens in EVERY truck story. After all that, like 6 trips to the hardware store, many confused hours of sitting in my floorboard, and i finally got it all cut, hung, and all was good.... I found the bracket.  | | |
