Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (Wayne67vert, baldeagle, Joe W), 69 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#212063 07/19/2006 2:51 AM
I'm trying to fabricate a mount hanger sorta thing, and I need to put a few holes in the "band" part of a hose clamp. Well I bought one, and tried to drill through it, no success. Tried to hit a nail through it, no success. Even tried to use a soldering iron to heat it up and hit a nail through it. No success.
This is a really thin hose clamp, so what should I use that will work to put a hole through it?
Thanks guys
GO RANGERS grin
Photos Updated so check them out!
#212064 07/19/2006 2:57 AM
Hey guy try putting it on a piece of hard wood and punching thru it with a punch. Sharpen it nice and pointy on the grinder first.
Lothar
#212065 07/19/2006 3:00 AM
What're you trying to hang? Those clamps are made from some tough material, you may need to check the projest metal section at the hardware store or farm store to get some thing that can be bent/drilled to make a hanger. If you a need to drill the clamp, try cobalt bits, they're more expensive, but they wil go through about anything.
Bill Burmeister
#212066 07/19/2006 3:00 AM
Heat it with a propane torch.It should be easy to punch through then.
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#212067 07/19/2006 3:25 AM
or get one of those plumber type hangers, not sure what you call them, they already have little holes in them,,not a clamp but you could probably put a small bolt thru them,, I used them on my rear lic plate to hang the topper plate, check my website, I cant for some reason post it here by its self
Redryder pix
My Hotrod
#212068 07/19/2006 3:35 AM
Well I tried punching through to the wood, and ended up with a bunch of broken nails.
Okay, here's what I did. I had a shaft radio, and I cut the dash for a DIN style rectanglar radio (slide in). Well the old shaft radio had a mounting bracket that held it up, so to keep the radio level.
On this new one, it's a totally different shape, so the mounting bracket won't work. I was gonna try to use a hose clamp and "hang" it from above, to make it level.
Don't have a torch, but I've got a punch, I'll try that.
GO RANGERS grin
#212069 07/19/2006 5:29 AM
I had the same thing with an underdash unit in my '53. I had a roll of the plumber stuff Joker is talking about. Used it as a ground aswell. Its just a band with holes punched in it. Should be able to find it at any hardware store.
Good Luck.
#212070 07/19/2006 5:37 AM
HardyRestoration,
If you can't punch, and you can't drill, the next option would be to GRIND! A little Dremel with a stone or carbide burr would buzz right through that sucka...I think! smile
Stuart
#212071 07/19/2006 2:10 PM
2 Offline
Hardy go to the hardware store and get a concrete nail. They are cheep and will punch throu it.
#212072 07/19/2006 4:09 PM
Yep, use that stuuf that Joker and Colin are talking about. Save yourself some aggravation. It's inexpensive, I believe.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
#212073 07/19/2006 4:42 PM
Plumber's strap or look in the metals section at your hardware store. You can find flat bar with holes in it. Cut it to length, bend as required. Sounds like you are working for the hose clamp, rather than it working for you. I believe it is made out of spring steel. Get something made out of mild steel so that you can work it. That spring steel has already been worked so it is REALLY hard to work it more, as you've found out.
#212074 07/19/2006 7:37 PM
Joker,Colin the plumber type or plumber stuff is called plumbers tape. Realy good stuff for radio support brackets. They use to send you a 10" piece with the radio.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#212075 07/19/2006 7:45 PM
it's called "perforated, galvanized PIPE STRAP" , and no decent shop is complete without a roll on the pegboard grin
#212076 07/19/2006 11:30 PM
thats it,, get you some...........I have some but you are to far away to throw it to you
This would work for sure
check it out
Redryder pix
My Hotrod
#212077 07/21/2006 4:33 AM
Guys, I don't know what I would do without you smile
Thanks!
GO RANGERS grin
#212078 07/21/2006 3:12 PM
you would probably lose an eye.
Another quality post.
Real Trucks Rattle
#212079 07/22/2006 1:23 AM
lol, that's ironic...i had to have surgery when i last worked on my truck cause i got metal nail bits in my eye
grin yum!
GO RANGERS grin
#212080 07/22/2006 2:35 AM
I got too close to some ragged sheet metal as I was useing the air chisel to cut out the old cab corner. Consequently I ended up going to get stitches.The wait at the hospital was so long (4 Hours),that when they removed them 2 weeks later ,the cut simply opened right up.Then it just closed up on its own eventually,next time I just won't bother going.Didn't my truck know ,I was just trying to help it? smile
#212081 07/22/2006 4:02 AM
super glue works pretty good at sealing up some cuts,,beats the wait at the ER,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#212082 07/22/2006 6:14 AM
Joker-where ya gonna find a screw to fit THAT hole??
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#212083 07/22/2006 6:50 AM
If all else fails a good heavy duty zip tie like you use to tie wiring works wonders.
#212084 07/22/2006 12:49 PM
2 Offline
Duct tape is the only way to go.
#212085 07/22/2006 1:43 PM
Amputation will solve all of your medical problems.... Including headaches..
1952 Chevrolet 3800 pickup
---All pictures---
#212086 07/22/2006 7:52 PM
Well to follow up this post, thought I'd throw in the classic story of what happens in EVERY truck story.
After all that, like 6 trips to the hardware store, many confused hours of sitting in my floorboard, and i finally got it all cut, hung, and all was good....
I found the bracket.
smile
GO RANGERS grin
