5 members (Otto Skorzeny, 2-Ton, TexasJim50, MickeyP, MRMEROTH11), 117 guests, and 3 robots.
Topics128,132
Posts1,056,383
Members48,441
#211539 07/10/2006 10:44 PM
My 1950 1300 has the gas tank in the cab. I have to keep the tank topped up until I fix the gas gage. When I leave the truck out in the sun on a hot day I see gas dribbling out the filler cap at an alarming rate.I figure this is due to the gasoline expanding.Aside from the cost of gas I worry about a fire. Should I invest in a new cap ? It looks like the original one to me.Or does any one think it's something else ? Thanks for any help . Jeff
#211540 07/10/2006 11:34 PM
you should not fill it so full, park so the filler is on the high side, stay outta the sun, quit smoking, and get the gauge fixed grin
my 58 does that in the summer if I overfill it
#211541 07/10/2006 11:57 PM
Thanks Uncle Bill... sounds like the advice I got from my better half this morning.
Jeff
#211542 07/11/2006 4:18 AM
The new cap will do the same if you get the correct, vented, cap. If you use an unvented one your fuel pump will quit pumping every few miles and you'll have to get out and let some air into your tank to get going again.
#211543 07/11/2006 5:43 AM
Quote
Me too. smile
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#211544 07/11/2006 6:24 AM
Thanks guys, now that you mention it the truck was always parked on a wee bit of a slope when this occured . I won't buy an unvented cap.I'll just get the darn gage fixed !
Jeff
#211545 07/11/2006 11:16 AM
Mine too. I blame the new "Do not top off" nozzles. They aren't AD friendly. I listen and click it off when I hear it nearing full.
#211546 07/11/2006 1:41 PM
I have experienced that same problem with all three 1966 trucks that I have owned in the past 21 years.
#211547 07/11/2006 2:02 PM
Cool, How about carring a 1 gallon gas can (So you will have extra fuel) and don't fill it so full till you get the fuel gauge fixed.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#211548 07/11/2006 8:41 PM
Thanks TYOVO,
Probably a good idea , and every one else thanks too. jeff
#211549 07/11/2006 9:07 PM
Mine does that too. Just park with the gas cap on the uphill side of the truck.
