0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 9 Junior Member | | Junior Member Joined: Jul 2006 Posts: 9 | WHAT TOOL IS NEEDED TO TAKE THE FENDERS OFF A STEPSIDE BED? | | | | | Joined: Mar 2006 Posts: 76 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 76 | You should just need a good socket set, that will get them off.
1961 k-10 86 c-20 02 duramax
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Since you are asking this, I'm assuming that they are not regular bolts, if so they probably are clutch head screws. If so, most of the vendors and even your local NAPA will have a set. Good Luck. | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | get a drill and a few good bits. most mine stripped out when i used the clutch head. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | IF you can't get those bolts loose, cut them off with a hacksaw, grinder with cut off wheel, dremel or die grinder, or even a bolt cutter. Just be careful with the power tools!
| | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | I had to use a grinder to get most of mine off. | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Sometimes what I find works the best for getting off rusted bolts is instead off trying to loosen them rather tighten them till the snap off. Beats trying to get the nut off all the rusted threading.
My 2 cents
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I found that the clutch head screwdrivers are worthless when trying to remove rusted bolts. I did the same thing that Highwayman decribes above. A quick turn to the right snaps the fender bolts off pretty easily. Replace the bolts with phillips head bolts.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Apr 2006 Posts: 51 Member | | Member Joined: Apr 2006 Posts: 51 | I have just been convinced to tighten the bolts now myself...Thanks :-)
old iron vs. new plastic....no brainer! TECH WANTED: on S-10 frame swap PARTS WANTED: 54 Visor, weather strips.. PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate 1954 GMC 3100 | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I turned my clutch head screws into slot heads with a cut-off tool.
delete my account and pictures
