0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#211395 07/18/2006 12:18 AM
Junior Member
Junior Member
WHAT TOOL IS NEEDED TO TAKE THE FENDERS OFF A STEPSIDE BED?
You should just need a good socket set, that will get them off.
1961 k-10
86 c-20
02 duramax
Since you are asking this, I'm assuming that they are not regular bolts, if so they probably are clutch head screws.
If so, most of the vendors and even your local NAPA will have a set.
Good Luck.
get a drill and a few good bits. most mine stripped out when i used the clutch head.
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
IF you can't get those bolts loose, cut them off with a hacksaw, grinder with cut off wheel, dremel or die grinder, or even a bolt cutter. Just be careful with the power tools!
I had to use a grinder to get most of mine off.
1965 Chevy C-10 Longbed Stepside
Sometimes what I find works the best for getting off rusted bolts is instead off trying to loosen them rather tighten them till the snap off. Beats trying to get the nut off all the rusted threading.
My 2 cents
38 original
48 panel
59 stepside
46 in the back forty
I found that the clutch head screwdrivers are worthless when trying to remove rusted bolts. I did the same thing that Highwayman decribes above. A quick turn to the right snaps the fender bolts off pretty easily. Replace the bolts with phillips head bolts.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
I have just been convinced to tighten the bolts now myself...Thanks :-)
old iron vs. new plastic....no brainer!
TECH WANTED: on S-10 frame swap
PARTS WANTED: 54 Visor, weather strips..
PARTS FOR SALE: I have complete frame / complete driveline from 54 1/2ton. very solid, will seperate
1954 GMC 3100
Tab Offline
I turned my clutch head screws into slot heads with a cut-off tool.
delete my account and pictures
Build or buy one of these if you want to get them screws out the easy way:
http://www.jalopyjournal.com/forum/showthread.php?t=6015
Jim
Good luck with your project!
