| | | Forums66 Topics128,114 Posts1,056,605 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | I have a trans am rear end on my 55. One side has a bent axle and it is leaking gear oil somewhere (I have not been able to find where). So my question is, "Is is difficult to pull out the axles and replace them and maybe change my gears? What special tools if any do I need to do this?
Roger
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Doesn't it have to be leaking around the seal on the bent axle? easy to pull the axle and replace the seal. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | The rear end can only leak an 4 places, each axle has a seal, the pinion has a seal and the cover uses either a gasket or rtv, some older rear ende hav a gasket for the chunk. As long as you are not replaceing carrier bearings or gears you will have no problem resealing the rear end.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
