1 members (Rich'sToys), 90 guests, and 2 robots.
Topics128,079
Posts1,056,310
Members48,442
I have a trans am rear end on my 55.
One side has a bent axle and it is leaking gear oil somewhere (I have not been able to find where). So my question is, "Is is difficult to pull out the axles and replace them and maybe change my gears? What special tools if any do I need to do this?
Roger
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
Doesn't it have to be leaking around the seal on the bent axle? easy to pull the axle and replace the seal.
The rear end can only leak an 4 places, each axle has a seal, the pinion has a seal and the cover uses either a gasket or rtv, some older rear ende hav a gasket for the chunk.
As long as you are not replaceing carrier bearings or gears you will have no problem resealing the rear end.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
