5 members (rfs56trk, Hotrod Lincoln, Jon G, Hush, Bill Hanlon), 118 guests, and 0 robots.
Topics128,105
Posts1,056,205
Members48,436
#211004 07/02/2006 4:59 PM
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#211005 07/02/2006 6:49 PM
use in front of address instead of and , like: your link - nice truck, get'er done! grin
#211006 07/02/2006 9:10 PM
try try again, my link COOOOOLLLLLLL! It worked.
#211007 07/02/2006 10:20 PM
Toyvo,
Nice looking truck! What are your plans with it? It does not look like it needs a whole lot.
#211008 07/02/2006 11:50 PM
grin practice makes perfect - in those first ones you left spaces after the [url= which "breaks the chain" - now you can figure out how to edit a post instead of making a new one - click the little [img]http://www.stovebolt.com/bboard/ubb//edit_ubb6.gif[/img] icon on a post [your own only] and it opens it again - in addition to editing it you can check the little box that says "delete post?" and when you click the "edit post" you eliminate it entirely grin
#211009 07/03/2006 12:01 AM
Nice collection!
The newer vette looks like my Dad's!
#211010 07/03/2006 4:20 AM
thanks bill i'll work on that.
Brendan, TY the toyota gets a complete make over, front and rear disc brakes, 350 cid chevy engine, lockers on the front, the rear already has them. Gonna use real-tree camo clad on the out side, and forest green rino-liner on the inside.
The scout has a 305 chevy, rv cam, edelbrock intake and valve covers, block hugger headers, quadra flood carb., 350 automatic transmission, 205 gear to gear transfer case, danna 30's front and rear, 3:56 gears front and rear with lockers, also has a pierse wench 12,000 lb., 2 inch add-a-leaf suspension lift, B&M slap shifter, black rino-liner interrior, and when the hard top is on has lights that shine front, rear, and both sides attached to the roof rack. My son tells me there ain't no place the scout wont go.
The Pinna Ferinna (fiat) is not stock, running about 10.2 in the quarter mile. she loves to eat stock 5.0 mustangs. It realy takes them buy surprise. She takes off like an arrow from a bow.
I have more pics (somwhere in this darn computer) of the scout whith the top on and the fiat with the hood up.
#211011 07/03/2006 4:34 AM
Oh 46, the truck is in great shape, her name is Betty Boop. She is seen there getting a much needed complete brake job, new everything,master cyl., wheel cyls,hoses,and shoes, rear axle seals, and wheel bearing pack. I have found an origional 1941 216 engine to replace the 235 some one else installed. It is at the machine shop and I should get it back this week. When the engine is out I am gonna make her back red again. She was born red she will grow old red and with all her origional parts, just like the day she was built.
#211012 07/03/2006 4:39 AM
I done good huh Bill?
#211013 07/03/2006 5:48 AM
grin perfect!
#211014 07/03/2006 10:26 AM
Nice collection of toys, Toyvo.
The truck is a real beauty, but it's easy to get distracted by that '54 vette. What's the tank and cover on the manifold side of the engine (I know almost nothing about the '54 Blue Flame Six)?
#211015 07/03/2006 7:01 PM
Thank you, I was as you are on the vett. Untill I found a website like this one that helped me. The tank is the radiator reservoir. The shield is to cut down on radio noise from the engine. The antenna for the radio is part of the deck lid it is molded into the fiberglass so it cant be grounded and picks up all kinds of noise from the engine.
We run her on aircraft fuel.
Oh did I mention that the numbers match the car build. She is the real deal.
